More than one tranny fill plug?
Old Jul 22, 2005 | 10:44 PM
Longshoe's Avatar
The Shogun of Harlem
Cool More than one tranny fill plug?
Cause I pulled mine and it starts flowing out as if I pulled out the oil drain plug. Granted the car was jacked up on its side but then shouldnt the level be a little lower anyway?? Im just confused how the tranny could have been overfilled that much unless the car was put on its side or something.
Just to make sure... the fill plug is the one circled in yellow in the attached pic right? Looks like it to me in the FSM and I didnt see anything else under there.
update: N/A 88 GXL
pic
Old Jul 22, 2005 | 11:03 PM
AcidShock's Avatar
Eet fase
Yes, that is the fill plug. I think turbo transmissions have more than one fill plug though. Your car should be level when checking or changing the oil in the transmission.
Old Jul 22, 2005 | 11:25 PM
Icemark's Avatar
Only Turbo trannies have 2 fill plugs
The one you have circled:
is the only fill plug for a (and that) non turbo tranny
Old Jul 22, 2005 | 11:29 PM
YearsOfDecay's Avatar
Locust of the apocalypse
From: Directly above the center of the earth (York, PA)
If the tranny was HOT when you did it.. you will get oil running out the hole even if its level.. it does expand a bit..
My guess is that the last guy to fill it, filled it with the car way jacked on its side. not you opened it either with the tranny warm or in warmer weather, and at a bit less of an angle and out it came!
BUT.. it needs to be level when you fill it....
ZacMan
Sep 19, 2015 09:20 PM
vmerino
Sep 5, 2015 11:26 AM
