Balance driveshaft near Eastern NC?
Anyone know where I can get a driveshaft balanced anywhere near Eastern North Carolina? The only place I have found so far is in Raleigh.
Thanks
ChrisR
Thanks
ChrisR
Get a hose clamp and put around it and ride down the road,check vibs then rotate it 180 and try agine then rotate it 90 and check and 90 the other way .If you feel a differance then fine tune it , rotate a little at a time from the best position .This may help untill you find a driveshift shop . The weight of the screw will act as the balance weight .
