Upgrading fuel system - question regarding fuel pressure dampeners
Old Jul 6, 2005 | 10:12 PM
FourtyOunce's Avatar
Simply put, I'm planning to upgrade my fuel system. Would there be any ill consequence if there were no fuel pressure dampener present?
Old Jul 7, 2005 | 12:34 AM
Carl Byck's Avatar
Mad Man
Irregular fuel delivery,at your level of mods a Marren FPD is a no brainer. About 110.00 from marren, place it between the rail, and the FPR. Most big power setups are run in series, secondary, primary, FPD, FPR, Return. If you run two lines in parallel, you should use two FPD. Carl
Old Jul 11, 2005 | 09:28 AM
S-MAN's Avatar
Does anyone have any pics of there upgraded fuel system? Mainley focusing on the secondary rail with the lines and the regulator. I'm trying to install mine.
alphawolff
Nov 17, 2015 05:57 PM
