okay, i capped off my EGR, and now my car has a check engine for EGR...
Old Jan 9, 2002 | 02:56 PM
legendr35's Avatar
hmm
is there a way to fix this? or Do i have to uncap the EGR?
thanks
Old Jan 9, 2002 | 03:10 PM
legendr35's Avatar
nevermind, i figured it out I forgot that my egr comes equiped with an electrical sensor.
Old Jan 9, 2002 | 09:50 PM
Mac's Avatar
Mac
Electrical EGR
So, it must be a '94 ? I had this same issue when I replaced the original '94 engine with a '97 J-spec engine, which has no EGR valve. The ECU continues to look for the EGR signal or you get a Check Engine Light Code 16.
Pettit advised to swap the ECU to a '93 ECU which does not monitor the EGR valve. I did and the Code 16 disappeared.
Were you able to get rid of the Check Engine light in anither way ?
Cheers
Mac
Old Jan 9, 2002 | 11:18 PM
California rx7s have an egr sensor. Spooledup7 gave some good advice as to get around the ecu error code when removing or diabling the egr using a 12 volt relay. I used a Bosch relay for about 3 dollars at radia shack. Do a search on this forum.
G/L
Old Jan 10, 2002 | 01:29 AM
legendr35's Avatar
G/L
thanks! but i decided to put egr back
Old Jan 10, 2002 | 02:03 AM
JeffShoots's Avatar
I'm thinking of selling my '95 FD Pettit ECU. It's nice and '95 has no EGR check light problems. 1995-on FD has no EGR at all.
E-Mail: jeffshoots@hotmail.com
Later, Jeff
Old Jan 17, 2002 | 04:06 PM
SORRY FOR ASKING SUCH A WEAK QUESTION,
BUT WHAT'S THE BENIFIT OF AN EGR VALVE?
Thanks
Kyo
Apr 13, 2019 09:24 AM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
