cluch problems
Old Jul 5, 2005 | 08:06 PM
okk0to's Avatar
maurice lives!
cluch problems
when i depress my cluch peddle for more the 5 or so seconds it will not return to the starting position and the cluch will not completely disengage. does anyone know why?
Old Jul 5, 2005 | 08:08 PM
d0 Luck's Avatar
raysspl.com
f"cked up pressure plate. or overall clutch system.. might wanna get it all replaced all together.
you still on original clutch and pressure plate?
Old Jul 5, 2005 | 08:33 PM
trochoid's Avatar
Old Fart Young at Heart
Clutch hydraulics. Replace the master and slave cylinder. Might as well replace the hose while your in there too. That way it's all done for another 10-15 years.
Old Jul 5, 2005 | 09:34 PM
northwoods's Avatar
I agree-clutch hydraulics. A seal is leaking, and fluid getting in front of it. Chuck it and spend 100 dollars and replace both master and slave cylinder and hoses while you're at it. Then it's really done.
Old Jul 5, 2005 | 10:28 PM
Mr_Rx7_Au's Avatar
Aussie Rx7 Freak
What these guys said. Replace master and slave, hoses, and line. Also make sure you bleed it properly so there is no air bubbles
Old Jul 6, 2005 | 09:41 AM
mazdaverx713b's Avatar
Have RX-7, will restore
try the slave cylinder first before the master. make sure you fully bleed it and if that doesnt help, move to the clutch master cylinder.
Old Jul 6, 2005 | 06:40 PM
okk0to's Avatar
maurice lives!
thanks guys
WyomingTII
Sep 28, 2015 10:32 AM
lnlreaper
Sep 27, 2015 09:59 AM
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
