HELP! Fuel pump fuse
Old Jul 2, 2005 | 09:19 AM
BinaryRotary's Avatar
Which one is the fuel pump FUSE. The search gives me nothing! Damn you search!
Old Jul 2, 2005 | 09:36 AM
Come on someones gotta know, I've been searching threads for OVER an hour.
Old Jul 2, 2005 | 09:50 AM
Bump. I'm stuck at home till someone answers.
Old Jul 2, 2005 | 09:56 AM
Elysian's Avatar
Bimmer *****
i dunno which fuse is for the fuel pump, check em all... and check ur relay too
Old Jul 2, 2005 | 09:59 AM
I know its not the relay it was running fine yesterday. I disconnected my choke and other garbage on the carb. I just need to know which fuse is for the fuel pump.
Old Jul 2, 2005 | 10:19 AM
lumberjk3's Avatar
on my '83 its the one at the top right corner that's turned 90 degrees from all the others, if you've got the old glass fuses, the haynes manual says its the one at the bottom left corner.
Old Jul 2, 2005 | 10:21 AM
lumberjk3's Avatar
if the fuses look fine, tell me what's going on with the car, I might be able to help
Dave
Old Jul 2, 2005 | 10:25 AM
Its a '85 GS with regualr fuses. Don't know if its the same diagram for the bus type fuses.
Old Jul 2, 2005 | 10:31 AM
What amp is that fuse? 15?
Old Jul 2, 2005 | 12:31 PM
HighwayRacer's Avatar
Family Mechanic
I own 5 1984 gsl-se's, and have never heard of a fuse for your fuel pump. Perhaps only so in earlier models but in the later first generations they have none. Test this philosophy by removing the box behind the driver side seat and find the rubber plug in the floor board with the wire running thru it, this is the power for your fuel pump. unplug the coupler and test the power while you attempt to start. Verify the line is truly dead. if the line is dead check your second fusible link in the engine compartment. 84-85 12a's have a rack on the firewall containing 3 fusible links. 13b's have 5. In both models and years its the second one down from the top. Logic behind no fuse for fuel pump.... in any scenario when the engine dies with the key still in the run positon... the fusible link kills the fuel pump for safety issues. there is no fuel pump relay of fuse or anything else. Trust me.
32 year Mazda Service Manager in Pensacola, Florida
Queppa
Nov 18, 2024 03:47 AM
Rotospectre
Mar 28, 2018 03:33 PM
LunchboxSA22
37
Oct 26, 2015 10:53 AM
ChrisRX8PR
Oct 18, 2015 04:01 PM
