Slop in wheel a problem?
Old Jan 7, 2002 | 04:21 PM
SlithyTove's Avatar
I just picked up an 85 RX-7 (fun!). Most of the car seems to be in good working condition, but there is about a half inch of slop in the steering wheel where it does not respond at all. Beyond that point it works fine.
Its not really enough to bother me (at least not yet) but I was wondering if it will cause any future problems leaving it the way it is for the time being.
Old Jan 7, 2002 | 04:34 PM
smnc's Avatar
EliteHardcoreCannuckSquad
The most likely culprits are either bushings or the steering box. Bushings are cheap and easy to replace, and it's easy to adjust the tightness of the steering box. You just wanna make sure you don't over tighten the adjustment bolt, or it'll cause rapid wear on the internal components.
Old Jan 7, 2002 | 04:43 PM
ladelberg's Avatar
Check you idler arm bushings, common culprit to steering wheel slop. Pretty cheap and common for them to go bad due to the exhaust manifold right next to it which bakes 'em......
Old Jan 7, 2002 | 05:45 PM
SlithyTove's Avatar
Thanks for the advice guys. I've been picking this sort of thing up slowly, but now that I actually have a car that I like I've been spending more time tinkering.
Old Jan 8, 2002 | 07:11 PM
FuLLsMoKe's Avatar
"By the beard of Zeus!"
If the slop doesn't really bother me.... should i adjust anything?
It's got about an inch of play...
Old Jan 9, 2002 | 04:01 PM
yayarx7's Avatar
Are you Nucking Futs?
If your bushings and ball joints and tie rod ends are ok and the slop does not bother you I say leave it. I drove around for 2 years with this prob and did not faze me
Queppa
Nov 18, 2024 03:47 AM
vqturbo
Old School and Other Rotary
32
Aug 11, 2023 07:29 PM
REsuper7
Aug 31, 2015 09:19 AM
primerGrey
Aug 25, 2015 02:46 PM
