Sponsored by: CARiD
no go rotary
Old Jun 21, 2005 | 12:22 AM
rotary rookie's Avatar
Unhappy no go rotary
hey guys I just bought an 86 rx7. After replacing the battery and spark plugs the engine still doesnt start. I put engine starter in the fuel injection and it lasted for one second on. I checked the spark plugs and they were dry. My neighbor said it has no compression but im pretty sure it does because when I remove a spark plug and crank it it blows spark. Any help is appreciated I just want my first rotary to be a good one.
Old Jun 27, 2005 | 12:43 AM
GUITARJUNKIE28's Avatar
multipersonality disorder
make sure the fuel pump is working, filter, injectors, etc...
if you're not getting fuel, it won't run.
Old Jun 27, 2005 | 03:02 AM
TurboSE's Avatar
if ....when removing the wires from the plugs ....still sparks! that doesnt mean U have compression.......................
1-Pull the EFI or EGI? fuses out
2-You have to pull the (actual) spark plug out!
3-then crank the engine(FUlly charged battery)
4-listen 4 the Loud (pshh-woosh-pftt>>????) sounds
5-if U can count 3 without cuts?Ur Compression is fine(Do One rotor 1st then the other one)
Old Sep 26, 2005 | 02:32 AM
rx_playa's Avatar
how bout ur coil? chickety check it!
datfast1
Old School and Other Rotary
18
Jun 20, 2019 10:53 PM
Under PSI
19
Sep 23, 2015 11:47 PM
datfast1
West RX-7 Forum
Sep 14, 2015 06:58 PM
andyvideopro
SE RX-7 Forum
Sep 5, 2015 06:56 PM
Murilli
Midwest RX-7 Forum
Sep 3, 2015 09:10 AM
