How big is the rubber on your FD?
Keep in mind that clearing the fender and clearing the fender lining are two totally diff ballgames. I run a 18 X 8.5 on a 245/35 in the front, and I have no prob clearing the fender w/ room to spare. The fender lining, however, is being eaten through on turns...
Originally Posted by rynberg
With the proper suspension setup and wheel selection, you can run a 285/30 18 up front.
If you see him running 285s all round in real life...dear God. It's MASSIVE.
Trending Topics
I don't suppose you have a pic you can share?
And thanks this is the link I needed http://www.scuderiaciriani.com/rx7/wheels.html#SIZ
Originally Posted by speedsilver7
my was 275/35 and 335/30
Originally Posted by Perry2
That is what, about a 24" high tire with a section width of maybe 9.7"? I wonder if the 1/4" difference between a 35 series and a 45 would have eliminated the rubbing. It wouldn't quite have the look of course
Here's a pic. 100% stock R2 suspension (every single component...for now), 245/35/18s w/ a +37 offset on 8.5s in the front, and 285/30/18s w/ a +41 offset on 10s in the rear. Don't jump on me for the offsets!! The FD simply is NOT a popular car, so finding nice rims in the correct size is very hard. On that note, I have absolutely no clearance/rubbing issues whatsoever, minus rubbing of the tire w/ fender lining in FRONT of the driver side front tire. The passenger side tire is fine... (which leads me to believe maybe the fender lining got damaged and started rubbing...) In fact, the rear needs a drop...but I'm changing the whole suspension anyways soon enough...
EDIT: Hmmm...I REALLY gotta get those rims polished (the whole thing). I like shiny
FC3S Timmy
Oct 2, 2015 08:08 AM
