View Poll Results: A/C related issue with Power FC
Voters: 15. You may not vote on this poll
Power FC A/C issues with Power FC
I'm trying to gather some info on A/C related issues from everyone with a PFC and if a fix was found. Please submit your info if you own a PFC.
YEAR: 93 R1
ISSUE: A/C only works on setting 1 & 2
FIX: none
YEAR: 93 R1
FIX: none
Trending Topics
I voted mine fixed, but it was really a workaround. The fix was the yellow/black wire going to the A/C relay cut and tied into the purple wire, which is the ground coming through the fan speed switch, A/C switch, and thermoswitch. I'm waiting for a better idea (like what poss has come up with and will post soon). I have to manually turn off my fans under high boost and start up (if I want). I cut the 4 wires related to emissions when I first installed it.
My system is converted to R-134a. My receiver/drier was leaking, and after years of not working, so was my compressor (the seals probably dried up). They have been replaced.
I have an fan switch and A/C relay for sale if anyone needs them. Before we knew what the problems were, I tried a couple of things out. The relay was brand new from the dealership, and was in my car for less than a week before we discovered the rest of the problems, and determined the relay was fine.
Originally Posted by Riccardo
Skeese
65
Mar 28, 2017 03:30 PM
