Can i keep my Auto rear end with LS1/T56 swap?
Old Jun 13, 2005 | 08:19 PM
bleach8484's Avatar
Im in the process of building a project car, FC3S automatic. Im going to do a manual conversion with a LS1 and T56. Will th egearing be ok in the Auto rear end? or would it be best to change out rear ends from a manual?
Old Jun 14, 2005 | 11:17 AM
theantirotor's Avatar
the gear ratio is fine... the strength of the gears is the problem. NA rear ends are not as strong as turbo rear ends and if you don't drive gently it will probably break
Azevedo
26
Mar 1, 2019 09:19 PM
mazdaverx713b
48
Apr 21, 2016 06:45 AM
