.81 or .96 Turbine Housings
Is the benefit of using a .96 housing compared to a .81
more Top end? at the cost losing a bit of bottom end?
doesnot really give you more power does it?
just changes the powerband ?
But can the .96 give you higher traps
then a .81
Thats the real question
then a .81
Open up! Search Warrant!
From what I understand, the larger the A/R ratio on the turbine housing, the longer it takes to spool up, or basically shifting the power band and the compressor housing is what dictates power.
then a .81
then a .81
yes to the top end. more power due to more flo which = more power, you will suffer a lil bottem end rpm will be about 250 rpm to about 500 rpm difference
really depends on the setup. for what it's worth. I run a .81 hotside on a "gts" wheel, and @ 28 lbs it yeilds at 543 whp. for me this is enough, some say w/ a
.96 the setup "should" lay down 580/600 whp I'm still trying to harness the power iv'e got now.
Good to know
I'm going to buy a .96 Tang
and compare it to the .81 I got now
My car pulls real good
but I feel it somewhat chokes up top a bit down the track 3rd n 4rth
we'll see
I'll compare both soon
at the track and the dyno
Then try a 4" DP
and compare that to the 3" DP
we'll see
Then try a 4" DP
Good to know
we'll see
Then try a 4" DP
we'll see
Then try a 4" DP
GOODLUCK!!! what kinda track numbers you lookin for?
