Microtech ignition question on microtech?
Old Jun 4, 2005 | 08:03 PM
fastcarfreak's Avatar
3rd motors a charm I hope
Hey guys, I was told that my HKS twin power will not work with my microtech LT12S with the new coils and x4 ignition. My question is, since im new to microtech, Do I need an aftermarket ignition amp like I needed my HKS twin power for my power fc. If so, what is needed. I have plans to run somewhere in the mid 20s for boost on race fuel. I have already ran 20 psi on my current setup, but now im changing to the microtech. Any and all info on the subject would be great.
Another question I had, Since i opted for the wideband O2 option for the microtech, is it possible to just run on a wideband O2 sensor. Or do i still need the stock O2 sensor in place. This is another area where im still new.
Thanks in advance!
Adam
Old Jun 4, 2005 | 09:01 PM
Turbo Timmy's Avatar
Professional Lurker
Sell the HKS you don't need anything else... Stock 02 is not needed either.
Old Jun 5, 2005 | 02:21 AM
so if i dont use the stock O2, do I have to have the wideband O2 in there? If not can i just plug it?
Thanks for the response by the way.
Old Jun 7, 2005 | 04:43 PM
I F****D a mermaiiiid
you don't need to have an O2 sensor plugged into the microtech. it is only there for datalogging purposes. the microtech does not operate in a closed loop manner where it uses O2 sensor signals to trim the fuel delivery under constant loads.
once you are done with your tuning you can remove the O2 sensor and put it on the shelf.
Ray
Old Jun 8, 2005 | 02:46 PM
sweet. thanks a bunch.
Nosferatu
Sep 5, 2015 02:13 PM
SakeBomb Garage
SakeBomb Garage
Sep 4, 2015 05:20 PM
SakeBomb Garage
Vendor Classifieds
Sep 4, 2015 05:19 PM
