electric fan
Old Jun 1, 2005 | 03:37 PM
Vagrant02_DRFT's Avatar
Touge Friend
electric fan
ok,search isnt working. Anyways, is their any benift to having an electric fan and how (if it does) benifit?
Old Jun 1, 2005 | 03:55 PM
WAYNE88N/A's Avatar
Only if you drive mostly highway miles...
I leave mine off for about 48 of the 50 miles I drive to work, all freeway, so there are obvious fuel & horsepower savings for me.
If you drive mostly city, you're gonna need to have it on most of the time anyway, so if your stock fan is still good, just leave it on there, you won't gain much if anything from an e-fan...
Old Jun 1, 2005 | 04:07 PM
aznpoopy's Avatar
strike up the paean
1) clean up the engine bay
2) make room for stuff (intercooler, piping, etc)
3) want more control over the fan
myth : you get 15 hp j0!
Old Jun 1, 2005 | 04:25 PM
J-Rat's Avatar
Alcohol Fueled!
Wayne..
Tsk tsk tsk.. You run your fan on a SWITCH instead of thermostatic control?
I am so disappointed in you..
Old Jun 1, 2005 | 05:01 PM
vipers's Avatar
IIMMM BBAAACCKKK!!
lol..... if anyone can wire a e-fan correctly, its wayne....... im kinda surprised too!! actually, anything to do with wiring is a no-brainer for wayne!!
Old Jun 1, 2005 | 05:03 PM
Touge Friend
where can you buy an e-fan at??
Old Jun 1, 2005 | 06:57 PM
AREITU's Avatar
cool story bro
You could always just run a thermostat trigger and a relay to click it on and off. For example, I know that some people ont he board run Escort e-fans. You could wire in a "normally open" relay so the fan stays on in case something fails. Basically when the thermo sensor is below a certain temp, it clicks the relay to off and turns the fan off.
Old Jun 1, 2005 | 08:09 PM
some aftermarket fans cool alot faster... and after they lower the temp they turn off... from the time they are off and the time they are on .... you do gain extra hp. when they are on i still think you save power but not enough to make a difference. the room it clears up makes it all worth it IMO
Old Jun 1, 2005 | 09:36 PM
Icemark's Avatar
There is almost no gain in any peak HP by using an electric fan on a FC--- maybe .5% (if that).
And add in the extra load that the alternator now needs, you loose any gains you might have made in the first place.
Old Jun 1, 2005 | 09:46 PM
rick_tj's Avatar
Bigger alt?
Old Jun 1, 2005 | 10:26 PM
aznpoopy's Avatar
strike up the paean
Originally Posted by rick_tj
Bigger alt?
the alternator is still drawing that power from the engine. its the same ****.
eh... i think the mech fan on a FC has a viscous clutch. it's not supposed to be on 24/7 either. it's only on when the viscous fluid heats up. its self regulating. based on this, the e-fan hp gain is going to be even smaller, if it exists at all.
if you're fan is on 24/7, it's seized - which isn't surprising on such an old car.
Old Jun 1, 2005 | 10:40 PM
Chris Ng's Avatar
I'm with stupid -----^
you have to really watch the current drain that an electric fan will place on your system.. especially in fuel critical situations (such as modified turbo applications)... I used to run an electric fan.. everytime that the fan would turn on, I would notice a voltage drop, at the point of the voltage drop, coinciding with this voltage drop, I would also note my air/fuel ratios go quite a bit leaner (monitoring on my fjo wideband).. what I ended up discovering was the fact that the current draw from the electric fan would affect my fuel pump voltages (this was checked via a multimeter) .. the resulting drop in current to the fuel pump also decreased it's output .... Just somethign more to chew on..
Old Jun 1, 2005 | 10:53 PM
J-Rat's Avatar
Alcohol Fueled!
I just want to know where the super electronics guru is, and why he chooses to rig his fan on a piddly little old switch...
Pffffft...
Old Jun 1, 2005 | 11:15 PM
Icemark's Avatar
well wired ideally, and electric fan would only be on when the temp of the coolant was above 180-190 and then off again when the car was in 5th gear.
Of course this would be by electronics, and not a switch that someone flipped on or off.
Old Jun 2, 2005 | 12:49 AM
NZConvertible's Avatar
I'm a boost creep...
How much power do you really think a thermoclutch fan is going to be drawing at highway speeds when it's practically freewheeling? Any fuel & horsepower savings under those conditions would be very, very small. Not obvious.
Old Jun 2, 2005 | 01:51 AM
ScrapFC's Avatar
Emerald Triangle for life
I went the efan (Stock Fiero fan w/a CarQuest thermo control and custom mounting bracket) route on my GXL and so far I'm pretty pleased with it. I don't see it making any noticeable increase in HP (maybe a small reduction in rotating mass), but it is aesthetically pleasing. I like hearing my engine when I rev it instead of the fan. I like having that much extra space in my engine bay. (It's also nice having easier access to the front of the engine...) I like how much faster my car comes up to temp now and how the fan runs for a little bit after I shut down, reducing heat soak in the engine bay.
The only thing I don't like is the faint nagging feeling of uncertainty that it might possibly fail. (Gonna wire in a fault light with a manual power switch next...)
Old Jun 2, 2005 | 09:14 AM
Aaron Cake's Avatar
Engine, Not Motor
http://www.aaroncake.net/rx-7/efanmyth.htm pretty much covers it.
Old Jun 2, 2005 | 10:05 AM
HAILERS's Avatar
HAILERS
Originally Posted by J-Rat
Wayne..
Now, now. Give Wayne some slack. After all he worked on A-6's I believe and considers them a modern jet.
Old Jun 2, 2005 | 11:38 AM
WAYNE88N/A's Avatar
Lol, I missed you while I was on vacation, Hailers...A6's definetly aren't modern. The EMB-145's I work on now definetly ARE. End of discussion...
Yep, mine's on a simple high current rated aircraft switch. Like I've stated several times, mine hardly ever is on. 95% of my driving is with no fan whatsoever, and she still runs at about 1/3 gauge tootin' down the highway at about 85*F out...
The only time I forgot to turn it on was when DPS pulled me over one night as I was going home. By the time I got back to the car, she was at about 4/5 gauge, lol...
Old Jun 2, 2005 | 01:05 PM
YearsOfDecay's Avatar
Locust of the apocalypse
From: Directly above the center of the earth (York, PA)
I guess its time for me to chime in on this one......
The biggest benifit i see to e-fans is that the engine rev's more freely whe it doesn't have to spin up the fan as well. Especially from idle.
There is another benifit to the E-fan that most people don't mention.. When you remove the air pump and run a dual pulley belt on the alt so that the water pump doesn't slip, a LOT of that slippage on the water pump is caused by the stock fan being attached to the water pump pulley. By removing the fan, you decrease drag on the water pump, reduce the chance of belt slippage, and also reduce stress on the alternator as you don't have to run the belts quite so damn tight.
I too am REALLY tired of the roar of the stock fan.. however, because of my front mount, I've always throgh i'd have to run it because the black magic fan seemed like it was on all the time....
Well, problem with the black magic is that it only coveres about 60% of the radiator core... thats not enough in my book. I'm going to switch to a Vintage Air Monster fan with a shroud that covers the entire radiator and give that a try. Also, I'm working on other ductwork to route some air to the radiator from under the FMIC rather than all of it having to go through it.
Old Jun 2, 2005 | 02:11 PM
J-Rat's Avatar
Alcohol Fueled!
Mmm hmm..
This is what I am talking about.
Note to the KIDDIES.. DO NOT FOLLOW UNCLE WAYNES PATH, USE A THERMOSTATIC CONTROLLER.
Shoot, when I was in Germany I worked on 63 model C-130s!
Old Jun 2, 2005 | 04:48 PM
well im guessin most people do it for the room they save ... i know that the power gain isnt even mentionable thats why i didnt really make it a big focus point in my comments... but i do believe that e-fans are better for cooling purposes not for power gains.
Old Jun 3, 2005 | 09:55 AM
Aaron Cake's Avatar
Engine, Not Motor
Sigh, do we really have to go through this again? Don't take this the wrong way, but if you believe this, then you don't understand how the cooling system works. The fan DOES NOT REGULATE THE TEMPERATURE. It is ONLY USED during IDLE or LOW SPEED driving.
Old Jun 3, 2005 | 11:55 PM
...mine's on a simple high current rated aircraft switch.
Why? Why not run it through a relay and use a light-duty switch and wiring?
You keep stating this as if it's somehow different to what would happen with a clutch fan. I think this is a bit misleading to those who don't understand how thermoclutches work (and there seem to be lots of them...). At highway speeds the stock clutch fan is literally freewheeling in the breeze.
I think that pretty much makes the case for a thermoswitch don't you? Seriously, the cooling system is too important to be anything other than fully automatic.
You've got that last bit wrong. The whole point of running a two belts is so that you don't have to run them any tighter than normal. I do not tension my belts any tighter than I used to before I fitted the dual-belt alternator pulley, and I have zero slippage.
Originally Posted by Aaron Cake
...if you believe this, then you don't understand how the cooling system works.
That would be my guess. I think there's more widespread ignorance about this topic than any other.
Old Jun 4, 2005 | 01:11 AM
Syonyk's Avatar
Wayne also has one of the highest regular fuel efficiencies of anyone in the 2nd gen section, and I've seen other people reporting gains of 1-2mpg just from switching to an efan. IN THEORY, the stock fan shouldn't be drawing significant amounts of power at highway speeds, but reality seems to argue, just as the fact that higher cruising speeds seem to net better fuel economy, despite theory saying that's ridiculous.
I'll get some economy numbers here in a week or two, as I'm getting rid of my stock fan next week due to running out of fan clutches to swap in (and getting quite tired of the process). This one seems to be not releasing, which is a nice change from the other ones I had fail that would never grip. It does make for some interesting fan noises as the engine winds up, though.
I've also talked to several people who noticed that their engines would rev up faster without the stock fan. Most of the difference seemed to be in the low RPM range, but it supposedly was a quite noticeable difference.
-=Russ=-
