Leading & trailing
Old Jan 4, 2002 | 09:02 PM
DCmina's Avatar
Question Leading & trailing
Hi, could you tell me which go on top and which go on the bottom?
Thanks!
Old Jan 4, 2002 | 09:26 PM
DCmina's Avatar
Help please! My car doesn't wanna start and it doesn't seem to be the battery.
This guy who repaired my radiator just changed the plugs and put the Leading ones on the top and Trailing on the bottom. Is that right, or is it the wrong way and causes my car not to start?
Old Jan 4, 2002 | 09:39 PM
DCmina's Avatar
Never mind I found my Haynes book.
Old Jan 4, 2002 | 09:45 PM
Xentrix's Avatar
Kill Bear
I'm probably wrong but i think the T is on the top and the L is on the bottom. the housing should tell you.
- in my haynes manual it shows a pic of one way then in the text is says the other.... odd
Old Jan 4, 2002 | 09:47 PM
xiaomingming50's Avatar
i believe the leading is on bottom... and then the trailing...
cuz that'd make the gases nearer the direction of rotation combust earlier than the ones near the intake.. in order to keep the direction constant.. hehe shrug am i rite?
Old Jan 4, 2002 | 09:53 PM
hanman's Avatar
REAL easy guys,
T=Top
L=Lower
Plus, they are labeled on the coils.
Once again,
T=Top or Trailing
L=Lower or Leading
hope this helps,
hanman
dona1326cosprings7
Oct 29, 2015 06:47 AM
GKW
Sep 28, 2015 04:34 PM
subeone
Sep 24, 2015 09:58 PM
