New audio wiring
Old May 30, 2005 | 12:07 AM
svs's Avatar
svs
Now with A/C ...
New audio wiring
The pervious owner had some fun with the audio my FC. I have new head unit but need to rerun everything. I’m getting a new power antenna, new component speakers for the front (with tweeters in front top corners doors), new rears, and antenna cable. Since everything is trashed, I can’t really tell how it is supposed to be.
Can I get a quick explanation of how this is supposed to hook up? Maybe an idea of were the wires should go?
And if I find any of the amps, they’re going in the trash.
Thanks
Old May 30, 2005 | 08:18 AM
purerx7's Avatar
Registered User
You will need to buy a new wiring harness for the headunit, mazda specific and also year specific. This wiring harness will have connect your power, ground, antenna and some other stuff to the head unit. THan on your headunit wiring harness the manual should state what each wire is for, connect the wires accordingly and that should be it. If you have components you will be wiring them to the crossover.
DocHoliday89
Oct 12, 2015 07:42 PM
cosmo7
West RX-7 Forum
Sep 14, 2015 09:47 PM
