Will this fit (HID)?
Old May 11, 2005 | 02:09 AM
Riccardo's Avatar
Will these HIDs fit on the stock pop up lights ?
Many thanks
Riccardo
Old May 11, 2005 | 01:56 PM
Riccardo's Avatar
Anyone ?
Old May 11, 2005 | 02:59 PM
DaleClark's Avatar
RX-7 Bad Ass
Hard to say. Easiest thing to do would be pull the headlight cover off and measure it yourself - they've got a ruler for size reference, so it should be easy to find out how much room you have to work with.
Dale
Old May 12, 2005 | 04:52 AM
Riccardo's Avatar
Thanks Dale
I will measure it
Old May 12, 2005 | 12:09 PM
jpandes's Avatar
Those should fit. But it hard to tell if the bulb base is an H4 base. I have a set of HID's in my stock headlight housings that also have the glare shield and they fit fine. The Glare shield really helps in preventing you from blinding on coming driver's.
Where did you find those HID's w/ the glare shiled? I need another set for my Acura. I'm blinding everyone. I always get highbeams flashed at me.
Old May 13, 2005 | 02:34 AM
Riccardo's Avatar
Thanks JPandes
These are H4 True Hi/Low
I have two places
www.hid4u.co.ok
www.xenonvalot.com
What do you think about the quality of the various kits ?
Old May 13, 2005 | 10:43 AM
nopistons94's Avatar
white FD lover
these dont fry the stock harness with all that power correct
Old May 18, 2005 | 07:31 AM
Riccardo's Avatar
Correct !
There should be no problem with the harness
Old May 18, 2005 | 10:53 AM
rx7what's Avatar
Norcal RX7 Pimp
the first link doesnt work and were are they at on the second link. They gave a lot of number names. what model # are the one you posted
Old May 18, 2005 | 11:38 AM
Scrub's Avatar
bow leggin'
I'm pretty sure HID uses less power then stock lights buddy
Old May 18, 2005 | 01:11 PM
Kento's Avatar
2/4 wheel cornering fiend
Correctamundo. A lot less, but I don't recall exactly how much.
Old May 18, 2005 | 07:36 PM
Chaosx1's Avatar
If you find out if these work, can you update us? I'm really hoping to find something to make my stock headlights brighter. It's so dark at night. Thanks!
Old May 18, 2005 | 07:47 PM
jic's Avatar
jic
volk racing
the fd in scrub's avatar looks sicc
Old May 18, 2005 | 08:35 PM
OKRX-7's Avatar
A.K.A. The Saint
I thought you had to have a ballast to run HID's...
Old May 19, 2005 | 12:22 AM
cmartinp28's Avatar
okrx.. you thoug right
Old May 19, 2005 | 12:33 AM
Scrub's Avatar
bow leggin'
haha, thanks it's my car my man
Old May 19, 2005 | 02:23 AM
Riccardo's Avatar
Sorry
www.hids4u.co.uk
Yes you need balasts
They have full kits
the correct kit is
H4 Hi/Low True Hid
Old May 19, 2005 | 07:47 AM
Scrub's Avatar
bow leggin'
the lighting is still not going to be perfect....the headlight housing on the 7 was not designed for HID. Someone did a BMW projector conversion not too long ago and I think it worked out pretty good. He was actually selling an extra set he had...don't know if he ever sold it.
Old May 19, 2005 | 02:15 PM
d0 Luck's Avatar
raysspl.com
conventional halogen is 55 watts per bulb, while HID uses only 35 watts.
there's no turning back once you go HID!
Old May 19, 2005 | 05:16 PM
white FD lover
Is there any set information anyone knows on buy a kit for the FD? I've gone through searches on this board as well as google, and all the sites listed are rather confusing and I can't find anything that I can move on. I want to buy a HID kit in the near future and I don't want to be sending money to the UK for somethign that won't fit correctly.
Old May 22, 2005 | 11:38 PM
Scrub's Avatar
bow leggin'
I am working on a HID conversion for the stock popups using the projectors from a BMW E46 and D2S2 bulbs....I will post more info when I get further into the project. There are a few obsticles to work around for example....the stock headlight lens is textured (fluted) and will affect the projection of the light and the cutoff.
I wish I could fin that thread where the dude put the BMW projector in the stock housing.
Old May 23, 2005 | 12:05 AM
d0 Luck's Avatar
raysspl.com
yeah you will definitely need projectors on them. w/o it, it bleeds profusely and will DEFINITELY annoy other drivers. trust me, i know
Old May 23, 2005 | 07:30 AM
Scrub's Avatar
bow leggin'
Not necessarily....if you buy D2R bulbs instead of D2S lights they have a built in shield to protect from that....The D2R bulbs are built for housings not designed for HID.
Old May 23, 2005 | 08:03 AM
Riccardo's Avatar
Very interesting Scrub
I didn't know that
BLK 93
11
Sep 9, 2015 10:56 AM
