Power FC Datalogit Anti Lag
Old May 7, 2005 | 04:15 PM
oligoon's Avatar
Newbie
Datalogit Anti Lag
Hi,
i've just started playing with my power fc/datalogit combo on my Mitsubishi Evo 6 TME (tommi mak edition) and am having a bit of bother getting the anti lag to work properly. i know this forum is for RX7 but you guys seem to know most about the topic.
anyhow the probelm is this:-
once the anti lag feature has been enable by clicking on the Enabled and Anti Lag switch on Settings 5 and the ignition turned off and on again, if SW3 on the datalogit box is earthed (the stated procedure to switch on the anti lag) the antilag does switch on but also comms is lost to the PC. This in itself is not a major issue - although annoying if you were in the middle of logging a load of stuff. however the real issue is that the anti lag does not switch off when SW3 is no longer earthed.
as i dont really fancy driving about with massively retarded timing this effectively means i cant use the anti lag.
any comments?
msilvia
164
Mar 8, 2020 08:00 PM
Nosferatu
Sep 5, 2015 02:13 PM
