10th AE
Old May 7, 2005 | 01:14 AM
bigdv519's Avatar
IFO Forced Induction Slo
Talking 10th AE
I weighed in at 2710lbs.
I weigh 235lbs.
Total 2945lbs.
Stock Turbo, Stock Intercooler, Stock Injectors.
10lbs of boost.
Fuel Pump Rewire w/ Walbro 255, APEXi S-AFC.
Custom Intake W/HKS filter.
Custom 2.5 Dp to straight pipe.
XS MBC @ 10psi W/32mmported wastegate.
No AC belt, PS removed, no emissions crap.
Original Motor W/124K miles, sat for 2 years.
Stock rims and tires @ 16psi.
Dumping at 5.2K rpms.
R/T .603
60' 2.167
330' 5.920
1/8 9.061
MPH 78.72
1000 11.776
1/4 14.078
MPH 97.68
14.078 @ 97.68mph
Old May 7, 2005 | 01:38 AM
SmogSUX's Avatar
No money. No love.
nice time. you need to use the flash on the slip though :P
Old May 7, 2005 | 01:53 AM
bigdv519's Avatar
HAHA.. I tried the flash and all I got was a white glowing slip.
Old May 7, 2005 | 05:58 AM
87RX7TII's Avatar
Why....so..... dark.....blurry......cant ..........see.....*squint*
Nice run though!
My mods are pretty much the same so I can now see what I should be running!
Old May 7, 2005 | 09:50 AM
BGH's Avatar
BGH
Very nice run. Is that with the stock clutch?
Old May 7, 2005 | 12:36 PM
pengarufoo's Avatar
The mystery of the prize.
no need for flash, but some ambient light would be useful!
10psi, I'd expect somewhere in the13's, did you spin? 2.1 60' isnt too bad but 2.0 would put you in the high 13's.
Old May 10, 2005 | 10:04 PM
bigdv519's Avatar
Yeah, thats with a stock flywheel and clutch. I learned that the clutch slips just a tad bit when I shift to second. I'm also running about 1/4 tread in the rear tires. Some more experimentation with different tires/rims, tire psi, and launch rpms. I also plan on beggining trails on a new clutch and light weight flywheel. Then I might be able to ease out the clutch instead of dumping.
Old May 12, 2005 | 10:55 PM
Impreza2RX7's Avatar
Try slipping it from 4500 rather than dumping the clutch.
yr6
Oct 4, 2015 12:23 PM
