best off set and tire size on this body kit?? (18x8.5f,18x9.5r)
Old Apr 30, 2005 | 04:57 AM
toylee's Avatar
i have same body kit as below picture(wide body). i lke to go with 18x8.5f and 18x9.5r. but not sure with off set and tires size. should i try +36f and +35r with 235/40/18f and 265/35/18?? any comment on this setup....
Attached Thumbnails best off set and tire size on this body kit?? (18x8.5f,18x9.5r)-473545%5B1%5D.jpg
Old Apr 30, 2005 | 01:43 PM
toylee's Avatar
Old Apr 30, 2005 | 01:49 PM
rynberg's Avatar
Those are pretty skinny wheels for a widebody, especially with the fronts. You should be looking more at 9.5 up front, 10.5 in back, at least.
Old Apr 30, 2005 | 02:08 PM
toylee's Avatar
rynberg,
my body kit is not that wide like other. its pretty close to fender flairs about 1" to 1.5 inch wider than stock. how about off set? will it be fine?
Old Apr 30, 2005 | 04:36 PM
rynberg's Avatar
You can run 18x10" wheels in back with stock fenders and suspension, 9.5 with wider fenders is going to look a little puny.
If the fenders are an inch wider in the back, you could run 18x11 with an approximate +40 offset with 295/30 18 tires. In the front, I would run 18x9 or 9.5 with 255/35 or 265/35 tires, offset would again be +40 or so.
If you are set on 18x8.5/18x9.5, then anything down to a +25 offset will be fine. You should know that running wheels with offsets significantly lower than the stock +50 will affect suspension geometry and increase wear on the wheel bearings.
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
