Engine Management Forum Use this area for discussing Haltech, Wolf 3D, Power FC, AEM and any other aftermarket ECU upgrades. Help/Questions/Tuning
WI working with emanage?
Old Apr 29, 2005 | 07:09 PM
torean's Avatar
vac leak
is it possible to run a water injection system with the emanage?.....maybe hook it up to the additional injector map?.....i have a kit and e-manage and thought other might be interested in it as well
thx
Old May 8, 2005 | 11:10 AM
The Griffin's Avatar
Burning up Time
it would work if you used something like "aquamist's high speed valve" so you can control the duty cycle as it has pretty much the same characteristics as driving regular fuel injectors.Otherwise you need fuel like injectors that are of stainless steel construction and will work with water.
maikelc
Aug 24, 2015 11:04 AM
