Upgrading my Pettit chip... Which one do I swap?
Hey guys,
I just picked up an unlimited chip from Pettit for my Pettit ECU. I'm trying to figure out which of the two chips that Pettit installs I have to swap. There's one that they install on the main board & another on the daughter board. Do any of you know which I need to pull? Thanks for the time!
-Mike with the R1 begging for it's computer back
The chip on the main board is for ignition, boost, and boost cut. The chip on the daugter board is for fuel. Which upgrade chip did you get? They should give you both right?
Chuck Huang
Chuck Huang
is it the wrks chip that goes on the daughter board and the exe that goes on the main???
does anyone have correct air fuel or five gas ppm levels for a correct rich/lean mixture?
Thanks,
Andrew Wojteczko
Thanks,
Andrew Wojteczko
