Freakin Brakes Keep Squeeling!! Help
Old Apr 17, 2005 | 08:21 PM
Ok.... three times now i have taken my brakes apart to try to stop the squealing.... now its pissing me off.... i replaced the old brakes with newer mid quality napa bads.... there were no squeals before i changed the pads... now they squeal whenever im not breaking.... i am using the original shims from the old brakes.... should i not use the shims... the strange thing is the passenger side doesnt squeal as much... also it seems to squeal when the wheels are turned certain ways... like if i hit the brakes and then keep the wheels straight it wont squeal for a little while untill i turn the wheels.... also, the passenger side doesnt have the metal spring wire thingy... and the drivers side does, but the drivers side squeal so much.... what should i do, im thinking new hardware kit
oh yeah and i lubed everything up way good with 3 different types of lube (a different kind each time i tried to stop the squealing
anyways thanks much for any help, ima go insane if i cant stop the squeal....
chiefmg
Sep 10, 2015 07:46 AM
Tem120
Sep 7, 2015 09:53 AM
Frisky Arab
Sep 4, 2015 06:17 PM
