Power window problem
Old Dec 28, 2001 | 09:20 PM
Pumped's Avatar
my driver side power window switch is not working..
the passenger power window switch works, the on/off switch seems to work, because when in the off position the passenger window doesn't work... i checked the #6 40 Amp fuse in the small main fusebox and it was not blown....
any suggestions???
Old Dec 28, 2001 | 11:12 PM
Trexthe3rd's Avatar
Take the switch out and spray electrical cleaner, see if u can get some movement from the windows that way. It sounds like a bad contact to me.
