Turbo Timer Install help
Old Dec 28, 2001 | 07:03 PM
I jsut got my Blitz cual Turbo Timer in, and the directions are great, and in Japanese. The English ones that come with it are less then stellar, and not rx-7 specific.
So if anyone has any experience installing one of these (I have the wiring harness) or turbo timers in general, I could use any helpfull hints before I figure it out myself.
Or if anyone knows of any good sites with the info, that would be good too.
Thanks
Old Dec 28, 2001 | 07:49 PM
Dyre's Avatar
Your Opinion is Wrong
Well in general....
You need to just plug the harness inbetween the one that goes to the ignition right now...
Sooooo.
Ignition -> <Turbo Timer > <-Car harness
Then you should have three wires left, 12v power (constant), Ground, and an Accessory source, a 12v power source that comes on only when the ingition is set to acc....
Ground should be black, power red, and acc like green or blue.
It SHOULD tell you what is what in the instructions. Hope that helps.
Old Dec 29, 2001 | 04:30 PM
follow ups
OK, so how hard is it to get to the ignition. I took a look, and it looks like I have to take the Steering wheel off to get to it. Right?
Also, what's a good place to go to for power and Acc power. I can figure it out through guess and check, but there's probably a good source, one of the fuses?
Old Jan 2, 2002 | 10:57 AM
Bump
it up
Th0m4s
Feb 26, 2019 02:04 AM
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
