Will this fit?
Old Apr 4, 2005 | 07:39 AM
Saner's Avatar
Porn Star
Will this fit?
Will these tires fit on an FD without any rubbing issues or modifications?
275/35-18
on
9 1/2" wheel with 35 Offset
Old Apr 4, 2005 | 07:47 AM
diyman25's Avatar
RE for life
mm.. you are pushing it. I used to have 18x9.5 offset 38 F/R with 255. but my ride hight is pretty hight and and had about -2.5 camber
Old Apr 4, 2005 | 09:54 AM
cabaynes's Avatar
Old and grumpy
that 35 offset is really bad, something between 45-50 would be ideal with that tire. you'll probably end up needing some heavily rolled fenders if you plan to lower the car.
Check this thread out
https://www.rx7club.com/suspension-wheels-tires-brakes-20/fd-wheel-fitment-page-390021/
Old Apr 4, 2005 | 02:38 PM
Saner's Avatar
Porn Star
Interesting
Old Apr 4, 2005 | 08:16 PM
rynberg's Avatar
Will most definitetly require fully rolled fenders in the back. Don't even try it up front.
Old Apr 4, 2005 | 08:22 PM
7racer's Avatar
hey whatever happened to that guy who bought the 19 +25 for the back???
Old Apr 5, 2005 | 06:27 PM
Saner's Avatar
Porn Star
What's the widest tire I can go for in the rear?
Old Apr 5, 2005 | 06:55 PM
rynberg's Avatar
The problem isn't the width, it's the wheel offset, which is way too low. You can easily fit a 285 in the back with the proper wheel offset.
Old Apr 5, 2005 | 08:56 PM
mark57's Avatar
Temple of Cornd0g
I think the best wheel/tire sizing is 245/40/18 F and 275/40/17 R. According to secret-secret tire calculator, the circumference is nearly an exact match - it won't screw up the ABS computer.
Old Apr 6, 2005 | 03:53 AM
rynberg's Avatar
You do not want to run that large a tire diameter up front. Small differences are not going to mess up the ABS computer. If you are that concerned about it, I would stick with much better diameter tires -- 235/40 and 265/35 18, 245/35 or 255/35 and 285/30 18, etc.
EDIT: Don't forget, the calculators are nice but they don't account for the fact that every tire manufacturer has their own sizing -- some Pirelli 265/35 18 are only 25.2 in diameter, while my Toyo T1-S in that size is 25.4 in diameter.
Old Apr 6, 2005 | 09:32 AM
mark57's Avatar
Temple of Cornd0g
Yeah, you're right. 18's have much better size options than 17's.
Old Apr 6, 2005 | 09:47 AM
RedR1's Avatar
Out of order
Granted everything else is taken cared of, 285's will fit up front
Old Apr 7, 2005 | 08:37 AM
Saner's Avatar
Porn Star
Ok, so what tire size should I go with for the rear? I can't return or exchange the wheels so I have to make the best out of it. I would like the widest tire possible.
Old Apr 7, 2005 | 02:15 PM
diyman25's Avatar
RE for life
this really depend on your ride hight and camber. for the front if you plan to lower you car. use some narrow tires ( some thing like 235) so overall wide will be smaller. and the rear you should be fine with 255-265 tires
Old Apr 7, 2005 | 03:45 PM
Saner's Avatar
Porn Star
I'm lowering it using the Eibach Pro-Kit Springs, and I'm not sure how low it's going to be. Will I need a camber kit?
Old Apr 7, 2005 | 05:59 PM
rynberg's Avatar
In the rear, lowering the car will have nothing to do with whether or not the tire clears the fender or not. And no, you don't need a camber kit, the FD has a real suspension, not MacPhereson struts.
With a 18x9.5 +35 wheel, I would try a 265/35-18. It should clear the fender lip, but it's going to be close. Depending on the exact tire model and camber setting, you may have to roll the rear fenders.
Old Apr 8, 2005 | 07:23 AM
Saner's Avatar
Porn Star
Thanks, rynberg! I'm going to give the 265's a shot.
cewrx7r1
15
Aug 6, 2018 11:41 AM
BLK 93
11
Sep 9, 2015 10:56 AM
