Engine Management Forum Use this area for discussing Haltech, Wolf 3D, Power FC, AEM and any other aftermarket ECU upgrades. Help/Questions/Tuning
FJO bosch sensor?
Old Mar 28, 2005 | 01:21 PM
teamafx's Avatar
FJO bosch sensor?
What sensor would you guys suggest I go with for the fjo wideband units, would the cheaper $60 BOSCH LSU-4 sensors work? or do I need something different, I have searched, just cant understand the $189 for each sensor they are asking
Old Mar 29, 2005 | 06:14 AM
RETed's Avatar
Why don't you ask FJO?
-Ted
Old Apr 12, 2005 | 12:58 PM
DCrosby's Avatar
No it's not Turbo'd
FJO uses Honda NTK Sensors as far as My FJO Unit Goes... and they're $289.00 a pop
Supposedly the Bosh Sensors last less long, but are supposedly just as accurate, the honda sensors last 30-50k Miles, the Bosh ones supposedly last 1/2 to 2/3 that long...
Old Apr 21, 2005 | 05:34 PM
GUITARJUNKIE28's Avatar
multipersonality disorder
supposedly this, supposedly that...
my lsu4 (6066) lasted more than 30k miles before my car got jacked, and was still accurate. 8-10 inches after the turbo, halfie bp.
Old Apr 21, 2005 | 05:53 PM
rynberg's Avatar
The FJO sensor control unit is calibrated for the NTK1 sensor, that's what you have to use. I don't know where $290 came from, hell you can get hand-picked NTK1 sensors from FJO for under $200.
The NTK1 is considered superior for turbo-rotary applications as several people have found it to be more tolerant to high exhaust temps than the Bosch units.
Old Apr 21, 2005 | 08:28 PM
when you say bosch, you should probably specify which one.
the 7057 sucks, but the 6066 is pimp.
