My Project and how it's coming....FD
Old Mar 23, 2005 | 07:30 PM
dhahlen's Avatar
FD Under Construction =P
ALright, here are some recent pics... I've never done this kind of crap.. doing a custom single setup, but here's what I have so far....
YOu can find all the pics at this URL:
http://photobucket.com/albums/y93/dhahlen/
Here is what I Snapped before I stopped working today:
I've got a TON Of cleaning to do, rust busting etc...
I am not sure where half of the stuff goes... what I should do with all the electrical connections, and what I Need to block off and what I don't... anyway if you have any input, please throw stuff my way.
THanks,
-DArren-
Old Mar 24, 2005 | 11:03 PM
widebody2's Avatar
addicted to lounge
haha you have so much work to do man haha. I remember when my car looked EXACTLY like that wow. Step one would be to get those holes covered up...you don't want a nut or any debris falling down there. I just stuffed a bunch of paper down mine...I think i used duct tape on some too. Don't forget to put new plugs in while you have the engine bay ripped apart...it'll be easier now.
I would say start with the turbo...getting that thing on there may or may not be a pretty big project in itself since its so large. You are going to have to clock it to the loactions that work for your setup. Also remember that the oil drain should be no more than 20 degrees away from straight down. Then start making the dp because that isn't the easiest thing in the world either.
I can't see the picture right now but if you don't have the LIM on forget about trying to fit the turbo, because the LIM is one of the potential obstacles
Old Mar 24, 2005 | 11:10 PM
widebody2's Avatar
addicted to lounge
Get that bottom tray off the car so you can stand in the engine bay...it will make your lief so much easier. Also Get the car jacked up a bit...it'll save your back
Old Mar 24, 2005 | 11:12 PM
widebody2's Avatar
addicted to lounge
If you aren't keeping your AC you can start removing the lines. The are in the way anyway...I kept mine but it was a pain
Old Mar 25, 2005 | 12:49 AM
dhahlen's Avatar
All the piping (downpipe, intercooler piping, etc) anything that has to be hard pipe is going to be done by the shop. Once i get everything on (Aside from the front mount, and the downpipe) i'll take it to a shop and have them fabricate the downpipe and the intercooler piping to my liking =P I am not going to do that ****, so it will save me a ton of time... and it will run me around $300 to have it done for me.
Old Mar 25, 2005 | 01:21 AM
dhahlen's Avatar
Here is some current stuff... I have a few questions, help me out with this crap, haha.
THanks
Old Mar 25, 2005 | 09:58 AM
2a+RoN's Avatar
The feed line doesn't have to be within 20 degrees of vertical, only the outlet, because it is gravity whereas the feed is pressurized. That coolant hose in your 5th pic of your last post can get capped as it would normally feed the turbos, but you're running a oil only cooled now. Also the coolant return from the turbos can get capped as well or you could run a hose straight from the coolant feed to the coolant return if you don't want to plug them up.
Old Mar 25, 2005 | 09:59 AM
2a+RoN's Avatar
woops, that looks like the coolant return there, the feed doesn't look like its pictured.
Old Mar 25, 2005 | 11:53 AM
dhahlen's Avatar
Rockin, where is the coolant feed like located?
It's probably on one of the pics here
=P
Old Mar 25, 2005 | 02:59 PM
2a+RoN's Avatar
Its in pic 29 on your site. It's pretty much directy above the return.. There is another thread that I just posted in that has a good pic of it.
Old Mar 25, 2005 | 03:34 PM
dhahlen's Avatar
Tell me if I got this right =)
Old Mar 25, 2005 | 05:36 PM
2a+RoN's Avatar
Yup.
Old Mar 25, 2005 | 10:11 PM
widebody2's Avatar
addicted to lounge
Darren when this is all said and done this thread is going to be great for people who are doing this install themselves. Just make sure you correct anything you may have had confused with your red lettering. When we get to the electrical connector elims, those pics will really be helpful because that info seems to be difficult to get on this forum. I know it was for me at least. I think like the saying goes...a picture is worth a thousand words. With the electrical connector on the back of the coolant filler...did you just look for a broken wire in your mess of connectors. That wire will just come out from under the uim along with all the other wires so I don't think it should be that hard to find.
Old Mar 26, 2005 | 01:30 AM
dhahlen's Avatar
I plan on saving all of these pictures and getting a correct and accurate guide made to do a single install, it will vary depending on the setup, but sort of like rob robinette has done, i would like to have a guide out there for everyone that is jumping into the single project blind like I have =P
Anyway, another example of me being lost...
This is the LIM - and this bolts onto it, can I eliminate it, do I need it, whats the deal? LOL
I dont have my blockoff plates in front of me so I dont know if I can just cap this hole.. .I dunno what this thing does, haha.
Old Mar 26, 2005 | 02:56 AM
bolo_fd's Avatar
thats the air control valve, it controls air from the air pump to the cat and is also used for mounting one of those turbo control solenoid that ur going to get rid of
Old Mar 26, 2005 | 03:05 AM
dhahlen's Avatar
w00t acv is toast =P - YAY! haha, good, i dont want it anyway... lol
Air pump is gone, this serves no purpose, haha.
Thanks =P
Old Mar 26, 2005 | 03:08 AM
bolo_fd's Avatar
no thank you for writing this guide, these guides on this thread helped out alot
Old Mar 26, 2005 | 03:16 AM
dhahlen's Avatar
Theres more where they're coming from. I have to veryify this info like 3-4 times before I get it right. Thanks to widebody2 for dealing with my *** over the phone answering my questions, Greg (dont know his name on the forums), 2a+Ron, they're all helping out. I'll get a decent guide eventually.
Old Mar 26, 2005 | 11:47 PM
dhahlen's Avatar
Here are pics of how the SX regulator will be hooked up...
Old Mar 27, 2005 | 12:14 AM
93FD3S's Avatar
Big Snail
Thats one the cleanest ACVs I've seen inside and out..!!
Old Mar 27, 2005 | 12:49 AM
dhahlen's Avatar
haha yeah it is pretty clean, dunno why...
Old Mar 28, 2005 | 08:37 AM
dubulup's Avatar
development
good work...looks like you are having fun!
Old Mar 28, 2005 | 09:17 AM
CrispyRX7's Avatar
Polishing Fiend
This may or may not help.
The deltas: I retained all my emissions equipment (I'm not the tyep to slip the tester a 50 every time I need to pass testing). Already have fuel taken care of (simple 1300 denso drop ins) GT35R has a wet center section.
FWIW:
http://www.negative-camber.org/crispyrx7/gt35rpage1.htm
Regards,
Crispy
Old Mar 29, 2005 | 10:13 PM
widebody2's Avatar
addicted to lounge
Crispy that is a pretty sweet site. Its funny how there are so many different ways to do the little stuff.
Old Mar 29, 2005 | 11:36 PM
dhahlen's Avatar
ok, check this is where I am at. I re-routed the coolant line that comes from the engine block, and put it into coolant filler neck line.
Here I took the oil injector lines and tied them together, the nipple that is left here will be tied into the compressor housing, or the air intake to the turbo.
I machined down the primary injector housing and threw my 850cc's in my primary housing, and the 1600cc's in the secondary with the fuel rail.
Now I have to figure out where the hell to mount the SX Fuel pressure Regulator... ugh, pain in the ***.
