Wolf 3D Discuss the Wolf 3D Engine Management System
Wolf 3D My progress report
Old Mar 13, 2005 | 02:52 PM
RLC's Avatar
RLC
My progress report
Hi Guys,
I have been reading alot of the posts here. WOW!
I just need to say, after looking at what all has been
said I'm amazed that any of us have a car running.
I would like to list what I know from talking to alot
of you personally on the phone.
1. I thanked Rob in NY for helping people on the forum
and did this over the phone. I know that he tunes
using the Haltech "staging bar" set up. I have seen
the maps he has sent me. It works,I know this, alot
of Haltech uses have done this for a long time.
In one Rob's posts he mentioned that he was
surprised that I was the head of Wolf, when I did
not understand how staging works. I do quite well.
By the way the formula that I beleive he posted is
right. multiply the rpm by the load in the same cell.
like this if at 4000 rpm the percent is 50 and at 71
load the percent is also 50, then multiply .50 by.50
the result is .125 that means that in that cell the
secondaries are running at 12.5% of the primaries
in the cell.
I personally don't use the "staging bar" method.
You might ask why? Because the transition is
smoother. Stock EMS from the factory is alot like
a the "staging bar" set up. When the secondaries
came on line the car would somtimes bog or hesitate
or buck if the injector drivers were going out and
sometimes the motor would blow an apex.
2. The map that was sent from AU is fine for the car it
came out of. I saw that there was not much staging
of the secondaries and shared with the owner of the
car that they are going lean. I based this on looking
at the data log he sent me. At 7000 rpm 18-1 AFR
is very, very bad.
3. The set up for the CAS in sync & ref mode is the
0,4,5 that people have mentioned. This is if the
sensor is in the stock location.
By the way I was the very first person to set up
a second gen 24+2 with the new software. I did
this while on the phone with AU. It was sent to me
by WOLF for testing.
4. If anybody has a question about why I tune the
way I do please call me. There are lots of ways
to tune. Remember, what works for one might not
for the other. I have tried them all! By the way
I have been tuning high performance cars for
23 years. I have a pretty good grasp on it!!
Thanks, Chris 916-289-0488
Old Mar 14, 2005 | 07:31 AM
SPiN Racing's Avatar
Never had a problem with anything from you Chris.
Back in the bad old days when Ron was running things.. I first met you when he was unable to help and referred me to you. (After he had called you on several questions)
Always been helpful, and thankfully (Cause things work real well) rarely have to call you.
Old Mar 14, 2005 | 01:24 PM
nyt's Avatar
nyt
wow 18:1 and no blowup? crazy..
actually if youve looked at any of my maps in the last few months, staging is all gradual. wolf cant really do a 'staging bar' type setup because of the interpolation. there will be a very lean and a very rich spot as it makes the transition from high ms and low/no secondaries, to low ms/more secondaries.
so why is the offset 4 instead of 0? Is this so it can get a window to be able to fire the advance within that cycle?
p.s. hows datalogging coming? (once it stops snowing here i will release a datalogger for the wolf if one isnt out by that time)
Old Mar 14, 2005 | 10:27 PM
RLC's Avatar
RLC
Hi Guys
I have great news about datalogging. Wolf has signed a contract
with a software firm in AU. All the 3D graphs etc. will be released
in 4 months. The datalogging will be completed also. The format
will be the menu tree on the left, Guages on the right, the bottom
half of the screen will be your map and the top half will be the
3D graph. It will work with everything you all have already as far
as hardware.
The data file will be able to send in an e-mail etc. etc.
Chris
Old Mar 15, 2005 | 03:16 AM
CrackHeadMel's Avatar
Learned alot | Alot to go
Wondefull news, doyou have any screen shots? If not ill just have to imagine
-Jacob
Old Mar 15, 2005 | 01:18 PM
nyt's Avatar
nyt
Old Mar 15, 2005 | 04:18 PM
silverrotor's Avatar
Good content you have going on here RLC. Why spoil It with your deleted thread title? This Is a technical forum that doesn't need such titles as your former one. If you have any concerns you may PM me. Eitherwise, carry on.
Old Mar 15, 2005 | 09:15 PM
RLC's Avatar
RLC
I agree
Thanks Silverrotor didn't mean to offened, some
of the posts were sounding a bit heated and had
gotten off the track of just helping eachother out.
Old Mar 15, 2005 | 11:07 PM
nyt's Avatar
nyt
Old Mar 16, 2005 | 02:09 AM
rotamotive's Avatar
Red face
Originally Posted by RLC
Hi Guys,
is very, very bad.
My apologies on that map sent...
I sent the map the car was run-in with and not the race map...
Maybe this is why i didnt understand what nyt was getting at until i opened up the map and had another look...I must of deleted the wrong map... this map was only supposed to be revved to 3500-4000 as a runin map only...
I did tell the person it was sent to to take it easy and to get it tuned asap...
Again,i apologise...[the race map looks totally different]
Old Mar 16, 2005 | 09:48 PM
getbent69's Avatar
RLC - Did Wolf mention if the new data logging was supported on version 4 as well as version 4+?
Old Mar 19, 2005 | 01:18 AM
RLC's Avatar
RLC
More on the new software
All Wolf units will support the new software. It will be a free download
from Wolf in AU.
The trigger input sequence I have attached.
Chris
File Type: doc
Old Mar 19, 2005 | 03:41 PM
nyt's Avatar
nyt
well on an fd i can see the sync offset having to be set properly due to the fixed location of the pickups and trigger wheel.
on an fc trigger, since it can be turned, stock position may be 4.
according to this document you can set it to anything if you adjust the CAS accordingly.
since there are 12 teeth per 360 degrees of crank rotation in an fc cas, each increment of the offset should move your timing 40 degrees.
I'll have to play with it on the next car i wire, currently im happy with my modified cas. I see a couple errors on starting because of the slow cas speed/low voltage but never any when running.
Old Mar 19, 2005 | 04:44 PM
Michael Smith's Avatar
Thanks Chris,
I was going to write some standalone data logging for the Wolf because ther was none. I was actually going to make a "Automatic Tuner" based on the output of a wide band AFM/O2 sensor and relative load tables. The idea was to get a base map and start the car, warm it up then drive it lightly. The program would then change the map so that at light load it was 14.7:1 and at full load it would be 12.2:1. This would cut tuning times for the inexperienced. Once done Dyno tuning can clean it up! The problem is that I have no time to do this as I have so many other projects .
Regards
Michael Smith
Old Apr 16, 2005 | 02:24 AM
signofinfinity's Avatar
Coyote
Any news on the data logging? hows it getting along
Old May 16, 2005 | 10:05 AM
Coyote
my offset on the fd is set at 5.....with a skip of 5...
