Anyone knows if these would fit (FD)?
Old Mar 9, 2005 | 10:06 AM
cruiser's Avatar
Anyone knows if these would fit ?
I found a killer price on the wheels / tyres combo for the track for my FD, but the owner cannot tell me anything else but this about them:
"They were fitted on my Evo 7. It says on the wheels PCD ZO9. they also say SL1471, and 8Jx17H2"
What I also found was that EVO7 supposedly (anyone knows this for a fact?) has +38 offset. These would probably fit without fender rolling, or not ? Would they clear the calipers ?
The wheels with slicks are here:
http://cgi.ebay.com/ws/eBayISAPI.dll...tem=7960058435
Any help would be greatly appreciated.
P.S.: How could I instruct the seller to measure the offset ?
Is the center bore same for all japanese cars ?
Old Mar 9, 2005 | 10:22 AM
cruiser's Avatar
And another question - would smaller ET cause smaller or wider track width ? If smaller, then spacers could solve the problem, no ?
Old Mar 9, 2005 | 10:38 AM
cruiser's Avatar
Blah... this got moved to the section where no-one looks
Ok... according to http://toy4two.home.mindspring.com/offset.html the wheels with ET35 would be pushed 10mm out at the back. That shouldnt really be a problem IMO with 235 tyres.
And I found on evolutionm.net that centerbore is 67.1mm
Any opinions?
I think I'll get them
Old Mar 9, 2005 | 02:36 PM
1234rotor's Avatar
GearHeadMoFo
17x8" +38 should fit just fine. Especially with a 235 tire.
Old Mar 9, 2005 | 03:44 PM
cruiser's Avatar
But if its +35... its only 3mm difference... would that cause rubbing ?
Old Mar 9, 2005 | 04:04 PM
rynberg's Avatar
It should fit fine, although you are pushing the limits on the offset. But it's not going to be an upgrade in handling. Make sure the bolt pattern is 5/114.3 (most likely is).
Old Mar 9, 2005 | 05:19 PM
cruiser's Avatar
Yes, its 5x114.3 and CB 67.1mm. 8x17, ET35.
I will not improve on handling, but it is shod with slicks...so... I should gain a fair bit of grip
I may get same enkei's as you rynberg but in 17" size and black (ugh... will paint them white or silver, they're slightly used)
cewrx7r1
15
Aug 6, 2018 11:41 AM
BLK 93
11
Sep 9, 2015 10:56 AM
