Sponsored by: CARiD
spark plug question
Old Dec 20, 2001 | 03:50 PM
MaxRX7's Avatar
hambre y sueño
Arrow spark plug question
There are 2 types:
1) 2 Trailing (top) plugs, and
2) 2 Leading (lower) plugs.
NGK's are recommend.
1st question: which coil (one is next to the battery/fender and the other next to the strut/firewall/fender) is for the leading plugs and which one is for the trailing plugs ?
Note: This is for a N/A FC.
2nd question: What happens if you use 4 leading plugs ?, any ill effects ?, power loss ??
I searched the archive, but it is empty.
TIA !!
Old Dec 21, 2001 | 08:01 AM
Hyperite's Avatar
Vagina Junction
I have a 3rd gen, so i can't answer about the coils, but i can the plugs. Don't use 4 leading plugs. They are of temperature 7 and running these in the training holes can cause detonation. Most people run all trailing plugs (Temperature 9) to avoid unnecessary detonation.
~Tom
Old Dec 21, 2001 | 01:07 PM
Grimlock's Avatar
check it....
the one by the battery is the leading and you can use 9's (trailing plugs) more cooler that the leading which are the same plugs but a hotter range (7's). i run 9's all around but i have a TII.
The1Sun
Mar 18, 2018 11:08 PM
Skeese
65
Mar 28, 2017 03:30 PM
alphawolff
Nov 17, 2015 05:57 PM
Joe428
16
Aug 19, 2015 06:24 PM
