How much HP's expected from Street ports
Old Mar 1, 2005 | 11:59 PM
cagedruss's Avatar
How much Horse power can one expect from a Street port in a 6 port engine? I want to race a 2nd Gen in RS in SCCA and would be required to run a 6 port. How much can be expected with a Motec or similar fuel injection?
Anybody have any Dyno specs?
This is listed else where also. Really need some realistic HP quotes.
Thanks!
Old Mar 2, 2005 | 03:48 AM
Kim's Avatar
Kim
OBEY YOUR MAZDA
Expect some 200-210 flywheel horsepower, I streetported a sixer for my old FC.
http://64.9.213.132/rx7club.com/foru...d.php?t=349280
It had the stock mufflers, which ate quite some hp but it was nice and quiet
Old Mar 7, 2005 | 09:35 PM
brianjules's Avatar
181 hp @ wheels on my ported 6 port with 89 rotors
Old Mar 8, 2005 | 01:32 AM
7thFlame's Avatar
how much would it be to street port it?
Old Mar 8, 2005 | 07:55 AM
BMS2004's Avatar
Frankencar
go to Mazdatrix.com or Racingbeat.com and check their prices. IIRC it's like $700. But if you order the templates and do it yourself it will be much much cheaper, and before you ask how to port, search. There are millions of threads about it.
Ron
Old Mar 8, 2005 | 01:42 PM
Flynbryn's Avatar
street ported 6 port
I personally know of a E prod car in so california. That has a modifyed LARGE street port. and a modifyed S4 Intake that is making 280 + to the flywheel. It has been recently " de tuned" for drivability. But this has taken numerous hours of flow bench testing, burnt up stationary gears,and spent bearings. Probably 6 motors worth. So far, the ceramic seals have not failed though. So it is like the old adage How much HP you require depends on how deep your pockets are. I would think 200-220 would be reasonable on a budget.
Old Mar 8, 2005 | 06:52 PM
BMS2004's Avatar
Frankencar
I'd like to see the dyno sheet on that car before I believe it. PPorts are usually in the 280+ range. a NA SP will never make that much with 13b or 12A. Feel free to prove me wrong though.
Ron
Old Mar 9, 2005 | 08:05 AM
GT1-20b's Avatar
Originally Posted by Flynbryn
I personally know of a E prod car in so california. That has a modifyed LARGE street port. and a modifyed S4 Intake that is making 280 + to the flywheel. It has been recently " de tuned" for drivability. .................... I would think 200-220 would be reasonable on a budget.
Ponys maybe, but not horses!
Bill Gates' personal budget could not make an E-prod motor make those #'s
Old Mar 9, 2005 | 09:53 AM
jimeby's Avatar
old racer
Is that 200 hp range using stock injectors and no mods to the stock manifold & FI electronics?
I was told by JLC Racing in Kent that the most I could expect from a port job on my pure stock 85 SE was 15% because the stock FI and induction couldn't support much more flow that the porting would give. So, assuming about 135 hp for stock plus 15% would give me around 155 hp.
Old Mar 10, 2005 | 08:28 PM
tims's Avatar
I am scheduled to run my street ported 13b 6 port next wednesday(3/16/05). this is the second run(first was with broken side seals) on the dyno for this engine. I feel the 200hp at the rear wheels is very possible and I would like 225hp. I have heard rumours that some of the e production guys have gotten as high as 250hp at the wheels. If all goes well I'll post the results. the first run with the blown side seals resulted in exactly 100hp and that was with 3 of the rotor faces with 0 compression or basicly half and engine.
Old Mar 21, 2005 | 10:46 AM
84stock's Avatar
Another "gonna do" who never did! Why post what you're gonna do without showing what you "did". I call bullshit bullshit bullshit. Actually I'd like to call bullshit on 98% of all the gonna do'ers!
Old Mar 21, 2005 | 09:31 PM
tims's Avatar
I'll update everyone. I did not make the dyno test. The engine decided to act up the weekend before the test. I fixed the small problem with the ignition and I am scheduled to test again this coming friday,3/25/05. You don't have to worry about me not doing something. I will be at the dyno this friday. I may not rush home to my computer to fill you in, but I'll be there. I have run this car twice on a chassis dyno and each time there have been problems with the engine, so no need to post any results. Last time with two blown side seals it made 100HP at the wheels. The E-production guys running carbs are making 250HP to the rear wheels easily. unfortunately the EFI engine can only use the OEM intake manifold and throttle body. the carb engines can use any manifold and are allowed 44 or 48mm chokes(I can't remember which) this is very large and the shorter manifold they use is much better than the OEM intake. if the EFI engine could use a shorter custom manifold they could easily make the same HP number.
Old Mar 21, 2005 | 09:57 PM
BMS2004's Avatar
Frankencar
show me a EP car making 250 RWHP and I will show you a non-legal motor. We can only run up to 38MM chokes BTW
Old Mar 21, 2005 | 10:12 PM
cpa7man's Avatar
Racing is life!
I don't know about a 13b, but I do know that a 12a is capable of 230-240hp on the engine dyno. According to my sources this range is about all that can be had, ceramic seals and a large street port. Most using Weber IDA's fully flow tested, ported/polished intake manifolds with the best exhaust made.
If anyone is making 250 rwhp, let me in on your secrets.
Old Mar 21, 2005 | 11:11 PM
cpa7man's Avatar
Racing is life!
Double post
Old Mar 22, 2005 | 12:01 PM
Boswoj's Avatar
OK - I run an EP 12a and I have heard recent dyno rear wheel numbers from a competitor who runs a national quality 13b and I can tell you that you are WAY off base. There is NO ONE running a legal EP rotary that is getting anything like 250 rear wheel horsepower. This sound a lot like one of those "I heard from my buddy's cousin that you can get 300 hp with one of those new cyclone intake" kind of stories. Believe me, you're not close.
Old Mar 22, 2005 | 12:39 PM
ddewhurst's Avatar
***show me a EP car making 250 RWHP***
Show me also please.......... & being legal is required................
Have Fun
David
Old Mar 22, 2005 | 06:58 PM
tims's Avatar
As for legal that is always a question. I do know that more than one of the engines were run at the runoffs and went through the tech and inspection. I realise this does not guarantee it is legal but it was raced. I have heard the HP numbers from more than one competitor and they were all first hand accounts. They could have also been stretching the truth a bit also but they have all been very successful with their setups too. If my test is successful(engine survives) I'll post my results. And for sure my engine would be absolutely legal. In fact it is very tame compared to others. No ceramic seals or trick lightened(sp?) rotors.
Old Mar 22, 2005 | 07:10 PM
BMS2004's Avatar
Frankencar
this oughta be good... although would be encouraging if theres the slightest bit of truth to these claims.
Old Mar 22, 2005 | 07:38 PM
DriveFast7's Avatar
Blood, Sweat and Rotors
I saw one of pablo's early reasonably budgeted EP motor's with 48 dcoe and the bigger chokes (2 years ago?) put 188 to the ground. Starting this year EP 13b's can only use 38mm chokes and they're down on power.
Old Mar 22, 2005 | 08:24 PM
cpa7man's Avatar
Racing is life!
Take a look at the EP trap speeds from this years runnoffs. I know Trash is legal. He had trap speeds of 130. I don't know Neal and I'm not sure if he was running a 12a or 13b, but he was the fastest 1st gen with a trap speed of 133. Who is the guy with 250 rwhp?
http://www.scca.org/_Filelibrary/Fil...n-traps-ep.pdf
Old Mar 22, 2005 | 09:03 PM
tims's Avatar
Bob Neal is a good friend of Dave Lemon from Mazdatrix and is a very good driver. I believe he is running a 13b. Did they reduce the choke size recently for the carb engines? I said before I don't keep up on all the rule changes. These numbers were stated after the SCCA had increased the choke size for the carb engines. If they have since reduced the choke then HP levels are likely lower. I was putting my engine together early 2004 so things have likely changed since then. The one FI engine builder was still claiming similair numbers but they could not get it to last the whole race and the driver was not as talented as some of the other regulars so it never showed during the race. I have seen the lap times at some of our local tracks start to come down recently so something is happening.
Old Mar 22, 2005 | 09:56 PM
cpa7man's Avatar
Racing is life!
As stated above 38mm chokes/venturies are allowed for 12a/13b. Same rule since 2003. Well for sure no one is going to give up their go fast secrets. I know the 13b will out power the 12a, but with the 140lb weight penalty plus more engine weight, larger rotating mass, more frequent rebuilds my $$ are on the 12a in EP.
A correction to my last post.....Trash should have read Thrash as in Tom Thrash.....sorry Tom.
Old Mar 23, 2005 | 11:22 AM
Most have said that the Carbs are only getting about 210hp at the rear wheels. Now the EFi guys should be getting about 225-235 at the rear wheels. I know of 2 EFI motors that have reached those figures and have not blowen-up. Yes they have probably spent about the same on those engines as most people would have spent on there entire race cars.
We all have to remember though, that what one engine dyno readings say don't mean the same on the other side ofthe US. I also no that some figures have been based on Engine Dyno's then calculating the horsepower loss thru the drive train. You have to compare the same set-up. (i.e. same weight flywheel, same clutch unit, same transmission gears and rear end ratios. Also needs to be tested in 4th gear. Some dyno operators run cars in third gear to get it to spin up faster.)
Old Mar 23, 2005 | 05:43 PM
tims's Avatar
your right about the dyno numbers and also some dyno shops will use corrected HP numbers. the dyno will correct the HP numbers based on the ambient air temp and other things. That is why I do all pulls in the gear which is 1:1(4th on my current gearbox) and I don't use an correction factors. I also like to use the same dyno but this has been a problem. I have yet to use a shop that when I left I felt they knew more about the dyno than I did. Seems like alot of shops have bought the equipment but never learned how to operate it properly. The latest shop comes highly recommended and has a good track record, so we will see. I will give all details after I have finished the testing and tuning.
