will 19x8.5's fit an FC turbo2
Old Feb 18, 2005 | 11:26 AM
sorry if this has been asked before, i did search. I was just wondering cause i want 8.5's but they are only available in 19" for the wheel i was lookin at. Thanks for any help/advice
Old Feb 18, 2005 | 12:57 PM
YearsOfDecay's Avatar
Locust of the apocalypse
From: Directly above the center of the earth (York, PA)
no.... you need at most a 30mm offset to clear the innersuspension.. problem is, you get less than 30mm offset on an 8.5 inch wheel and the tires are going to poke out past the fenders....
unless you get a wide fender kit or skinny coilovers... i'd forget about the 19 inch rims because they don't offer them in widths that will fit under the FC front end....
cewrx7r1
15
Aug 6, 2018 11:41 AM
BLK 93
11
Sep 9, 2015 10:56 AM
