car won't start
Old Feb 7, 2005 | 12:09 PM
jphesterly's Avatar
car won't start
Ok well I pretty much upgraded evreything in the engine except for the turbos...even got a new fuel pump and power fc...well not my car wont start. It turns over but the damn thing just wont fire, I dont have a CEL, but fumes of smoke creep out of my exhaust... anyone have any ideas?
Old Feb 7, 2005 | 12:20 PM
ReDLiNe@t9's Avatar
mine wont start either
Old Feb 7, 2005 | 07:50 PM
TwinTurbo93's Avatar
0-rotor-0-turbo-0-fd
Did you replace the puleys, main pulley?
If yes, the CAS (crank angle sensor) plate is behind the main pulley and if you took it out and installed wrong your car will not start in million years, there is a mark to show you how to put it back. If that's the case I'll give you more info for complete installation, check its wires also.
Check that out..., Also check main fuses and fuel pump fuse and realys, Since you did all that work as you're sayng check also the coils and wiring some wire might be disconected or even cut of from working around... Start step by step...
EDIT: Check the igniter (on the left fender, behind the cruise control) wire harnes to, make sure that is properly connected..
Let me know.
Good luck.
Old Feb 7, 2005 | 09:40 PM
tt2323's Avatar
Import Connoisseur
wouldn't you wanna check for fuel/spark first? go from there...
alphawolff
Nov 17, 2015 05:57 PM
