just a simple answer is needed please
Old Feb 5, 2005 | 02:58 PM
zeromage428's Avatar
BWAAA
Question just a simple answer is needed please
i just started driving my vert with 17s, 225s
the previous owner droped it a little
this is the problem
whenever i take left turns at high speeds the passenger front tire hits the wheel well
but when i take right turns at high speeds the its fine with the drivers side wheel is fine and stays in the spot its suppose to be
what could be the reason with the passenger side hitting the wheel????
ima nub to the whole suspension thing so please people help me out
Old Feb 5, 2005 | 06:33 PM
rynberg's Avatar
What is the tire size/ratio?
Old Feb 5, 2005 | 08:00 PM
RETed's Avatar
Drivers tend to take left turns harder than right turns.
I think your tires and rims specs are not proper for the car.
For 17" and 225 width, the tire should be 225/45/17.
17" x 7" rim is ideally a +35 offset.
17" x 8" rim is ideally a +30 offset.
-Ted
Old Feb 5, 2005 | 09:49 PM
maxcooper's Avatar
WWFSMD
Also, it is not uncommon for one side to rub while the other side is okay. Don't be freaked out about that too much. Cars aren't really symmetrical, you don't sit in the middle, alignments can make one side more likely to rub than the other side, etc.
-Max
Old Feb 5, 2005 | 09:57 PM
BWAAA
so theres nothing i can do about the tire hitting the wheel well on the right side unless i change out the wheel?
Old Feb 6, 2005 | 12:51 AM
rynberg's Avatar
How about answering any of our questions first?
Old Feb 6, 2005 | 04:27 AM
RETed's Avatar
Doh!
-Ted
astrum
24
Nov 15, 2017 08:44 AM
befarrer
Microtech
Aug 22, 2015 05:52 PM
elfking
Aug 19, 2015 09:48 PM
