Wet CHRA question
Old Feb 4, 2005 | 06:08 PM
CrackHeadMel's Avatar
Learned alot | Alot to go
Wet CHRA question
Is it possible for coolent and oil to mix inside the chra? Are there seal's that devide the 2? or are they in seprate cavitites that would have to rust for the 2 to mix? Just trying to narrow down a coolent in oil issue
-Jacob
Old Feb 5, 2005 | 12:06 PM
Old Feb 5, 2005 | 12:12 PM
Marshall's Avatar
Seperate cavities, no seals.
Old Feb 5, 2005 | 06:16 PM
Thank you.
Old Feb 5, 2005 | 09:36 PM
Marshall's Avatar
No problem, the water jacket would have to be cracked for them to mix.
Old Feb 7, 2005 | 12:30 PM
Carl Byck's Avatar
Mad Man
A little oil in your coolant is normal, alot is not, if you're using coolant, you are almost certainly loosing your O Rings.
Old Feb 7, 2005 | 02:56 PM
Im not using coolent, however im missing oil ?? Its not smoking enough now to be burning 2qt of oil in 15min..
_Tones_
May 25, 2021 05:37 AM
younG_Gunner
Sep 9, 2015 08:26 PM
Nosferatu
Sep 5, 2015 02:13 PM
