18x8.5 +38, 18x 9.5 +43
Old Jan 26, 2005 | 08:19 PM
teamafx's Avatar
I have an eibach pro kit on the fd and was looking at some 5zigen wheels, would these work? I was told they would rub up front
Old Jan 26, 2005 | 10:16 PM
rynberg's Avatar
That is a pretty low offset for the fronts, especially with the Eibachs. You should most likely roll the fenders to prevent catching the tire on the lip.
Old Jan 27, 2005 | 08:27 AM
teamafx's Avatar
should I change the suspension then?
Old Jan 27, 2005 | 09:26 AM
SpeedKing's Avatar
Power Trippin'
An adjustable coilover system should do the trick, but instead of going through that unneeded expense, why not just get the front wheels in a higher offset?
Old Jan 27, 2005 | 10:16 AM
teamafx's Avatar
well the only offsets I saw were +38 and +48
Old Jan 27, 2005 | 10:42 AM
rynberg's Avatar
A +48 will fit perfectly....
