Wolf 3D Discuss the Wolf 3D Engine Management System
Wolf 3D HOWTO: FD Igniter with Wolf 3D v4
Old Jan 25, 2005 | 12:21 PM
nyt's Avatar
nyt
For some this may be self explanatory, for others here it is...
This is looking at it with the pins on the igniter facing up, looking at the top side of it. Pins from left to right. This matches up with the diagram on page G-16 of the FSM. Make sure you have the connector from the FD harness with the igniter also.
PIN 1 - Trailing Wolf (T1)
PIN 2 - To Trailing Coil (T1)
PIN 3 - Trailing Wolf (T2)
PIN 4 - 12V IN (switched)
PIN 5 - To Trailing Coil (T2)
PIN 6 - Leading Wolf
PIN 7 - To Leading Coil
PIN 8 - Unused (bridged to pin 7 inside the igniter)
from the FSM.
Old Feb 28, 2005 | 05:16 PM
teknics's Avatar
Just to double check, looking at the connector in the diagram is goes A-H, would the PIN1 in your description be PIN A or PIN H?
(just trying to clarify to make my install easier)
kevin.
Old Mar 1, 2005 | 02:39 AM
CrackHeadMel's Avatar
Learned alot | Alot to go
! Damn, now your making me unsure of how i wired mine.
Where are you mounting your ignitor? I removed the original trailing ignitor, notched a few places with my dremel and put the FD ignitor right where the FC trailing ignitor was
-Jacob
Old Mar 1, 2005 | 11:39 AM
nyt's Avatar
nyt
pin 1 would be A. I mounted my igniter on my firewall.
Old Mar 1, 2005 | 04:46 PM
teknics's Avatar
i'm making a mounting spot for my 4 blaster ss coils, 1 msd 6a, and fd ignitor. Ok so PIN 1 = PIN A, thanks.
kevin.
Old Mar 17, 2005 | 09:09 PM
VaGambler's Avatar
simple question
does the Fd ignighter do the same thing as going out and buying the bosh ignition module for the 2nd gen . Am I comparing apples to apples , or am
I missing something
Thanks in advance
Old Mar 18, 2005 | 01:38 AM
nyt's Avatar
nyt
fd igniter is a 3 channel igniter. its all you need. bosch seemed like a waste to me
Old Mar 18, 2005 | 11:31 AM
the bosch gives you the ability to run 4 individual aftermarket coils.
Old Mar 18, 2005 | 06:14 PM
you can run 4 coils with the fd ignitor. Just connect both leading coil inputs to the single channel of the ignitor together
-Jacob
Old Mar 20, 2005 | 05:19 PM
Net Seven's Avatar
-Jacob
True, the leading both fire at the same exact time. There is also only 1 wolf wire that goes to the stock leading ignitor.
Old Mar 20, 2005 | 08:50 PM
as long as the internal resistance is pretty high on those aftermarket coils (which is kindof defeating the purpose) it would work for a little while, but any type of high current coils is asking a lot of 1 channel in an ignitor, much less, 2 coils on 1 channel. Even the stout fd ignitor would burn up in a short amount of time.
Old May 16, 2005 | 08:35 AM
signofinfinity's Avatar
Coyote
Originally Posted by RotorMotor2
so do the T2's work now on PnP FD? or do i have to jump a wire? alos where is the oem FD ignitor?
no, the coils should work fine t1/t2 with the plug n play...
the fd ignitoris on the right hand side of the inner pannel. that is for the us on the driver's side. Its a flat heat sunk box with a flat square female socket on the bottom, usually silver but may be black. it gas a resisrtor little box also bolted with the mounting bolts. it bolts using to laterally opposed 6mm bolts...
Old Mar 5, 2012 | 01:32 AM
ShayMK's Avatar
Is there any way to make this work without having the harness for it? I bought a 13b motor and tranny with the wolf 3d v4 and came with an FD igniter and FC coils, the only thing I didn't get is the actual harness for the igniter. The way the previous guy had it wired was with separate connectors for each pin, I tried doing it that way (using this thread) and I'm only getting spark on the leading coils.
WANKfactor
Sep 29, 2015 01:14 PM
GKW
Sep 28, 2015 04:34 PM
subeone
Sep 24, 2015 09:58 PM
ncds_fc
19
Sep 15, 2015 12:03 AM
