Haltech Haltech E6X Help?
Old Jan 21, 2005 | 12:05 PM
mister2wisted's Avatar
Newbie
Haltech E6X Help?
I have a 88 turbo2 and jus had a haltech installed with 720 primary and 1680 secondarys injectors, i cant not get it started or a good base map, if anyone could help wit maps or trouble shooting or tips please respond, thanks
Old Jan 21, 2005 | 01:38 PM
jreynish's Avatar
New Project on the Way...
the stock Haltech map should get your car started. have you tried setup up the stock haltech map and trying that to get your car started?
Old Jan 24, 2005 | 09:32 AM
Newbie
yes i have, its just becoming flooded with fuel, ive even tried turning the secondaries off
Old Jan 26, 2005 | 02:30 AM
RX-7-8593's Avatar
This may sound overly simple but you said you had the haltech installed. Im asuming someone else did the install. I would check to see if they may have wired your injectors incorrectly. INJ 1 an 2 should be on the primarys and 3 4 on the secondarys. If there wired with the 3 4 on the primarys and 1 2 on the secondarys you will be trying to fire the 1600s at idle making it extremly difficult to start and will flood every time with the base map. I ask because I have seen this done once. A simple mistake.
