Does the width of the wheel effect the hight of the tire?
Old Dec 13, 2001 | 10:56 AM
Samps's Avatar
Would a 225/45-17 on a 7 inch wide wheel be the same diameter as the same tire on a 9 inch wheel?
Old Dec 13, 2001 | 11:50 AM
SpeedRacer's Avatar
Formula Mazda Driver
Yes, the height will be the same. Personally, I think stretching 225 around a 9" wide rim is a bit much though, unless you are racing it and want 0 sidewall flex. It will look a little funny on the road probably.
Old Dec 13, 2001 | 01:02 PM
Samps's Avatar
i was just using those sizes for an ezample. the set-up i am going for is 215/45-17 on a 17x7 and 245/40-17 on a 17x8, and according to the tire size calculator those tire sizes should be the same diameter. I just needed to know if the width of the rim would make a difference. thanks.
Old Dec 19, 2001 | 10:06 PM
Alex's Avatar
The tire diameter will change a bit, the sidewalls on one could be straight up but on the other they could be stretched out at an angle. Get your hands on a wheel and tire fitment guide, most tire shops should have one. Wheel size is also important for tire performance. If a wheel is too narrow or too wide, the sidewall won't work as it is intended, so you could lose steering feel or cornering grip.
