84 GSL-SE race/street alignment questions.
Old Jan 13, 2005 | 08:16 PM
elron90sc5speed's Avatar
Autocross'in fool.
Question 84 GSL-SE race/street alignment questions.
I am getting an alignment on Saturday Jan 15th and have never done an alignment on an RX-7 before. The car is used as an autocrosser and commuter car.
I don't know what all is factory adjustable on this car.
The suspension is stock except for Tokico Illiminuna II 5-way adjustable shocks.
What I want to know is what are the best factory adjustable settings for autocrossing that will not screw up tires too bad on the street.
I run the car in the stock class so any adjustments must meet SCCA stock class rules.
Thanks,
Devon
Old Jan 14, 2005 | 03:32 PM
Autocross'in fool.
No one has any suggestions? Just lookin for a little help here.
Old Jan 15, 2005 | 08:48 AM
APEXL8T's Avatar
boxed in and drawn out
zero toe....+5 caster .To save tires set stock neg. camber.
Old Jan 15, 2005 | 10:44 AM
RotaryAXer's Avatar
I would go about 1/16 to 1/8 toe out. As much caster as possible within spec and as much negative camber as possible.
Old Jan 16, 2005 | 03:15 AM
Autocross'in fool.
The most camber I could get was about -.5 of a degree.
I drive the car mostly on the street so setting too much toe out will destroy my tires and make it track worse than they did new.
Why do you think I should set it at 0 toe as opposed to a slight toe out (which is where the car is set now)?
Coochas
44
Nov 5, 2019 11:08 PM
NickNac113
13
Oct 1, 2015 09:25 PM
