Cable hook up to Jay Tech TB.
Old Jan 11, 2005 | 02:59 AM
Marcel Burkett's Avatar
Question Cable hook up to Jay Tech TB.
As a few of you (or maybe all for that matter) might know by now , I will be running a whole Jay tech intake on my motor soon , thing is I haven't figured out how to hook up the throttle camle yet . I found a few cable brackets used for carbs but I doubt they'll work on the TB since it uses an "arm" instead of a pully type attachment . Any one have any ideas , or has done this before and can put up some pics and maybe a short "how To" and part list ? , thanks. I've uploaded pics of the bracket and pulley ,in case any one doesn't know what I'm talking about.
Attached Thumbnails Cable hook up to Jay Tech TB.-hly-20-112.jpg   Cable hook up to Jay Tech TB.-throttle_pulley.gif
Old Jan 11, 2005 | 04:49 PM
KNONFS's Avatar
B O R I C U A
Is this the TB you are talking about?
If so, you can probably detach the arm, and use the this one instead:
For the throttle cable bracket, RB sells:
Hope this helps
Old Jan 12, 2005 | 07:17 PM
Thanks man!! , the RB bracket looks like it'll work with the "arm" type linkage . I ordered it already , I will post what I find.
Old Jan 13, 2005 | 05:50 AM
KNONFS's Avatar
B O R I C U A
The RB bracket is commonly used, the erst of the setups that I've seen, owners fabricate some sort of bracket; I rather use the RB one I am not sure about the TB arm though
BTW - You got a PM!
TeamRuffRacing
Sep 30, 2015 08:13 PM
choddaboy
Sep 26, 2015 06:35 PM
MidnightOwl
Sep 25, 2015 10:24 PM
