Power FC Is my car safe to drive on the Power FC base map?
Old Jan 6, 2005 | 10:43 PM
buzzer's Avatar
My mods are:
Apexi Power FC
Simplified sequential vacuum lines
HKS Carbon Ti catback
Rx7store resonated midpipe
HKS downpipe
Apexi intake
Blitz FMIC
1300cc injectors in stock fuel rail
supra TT fuel pump
profec b spec S
Would it be safe for me to drive my car around. I wont even boost it if i shouldnt. Im gonna get it tuned soon. just wanna know if its ok to drive around on base map on the Power FC
thanks,
Craig
Old Jan 6, 2005 | 10:54 PM
rynberg's Avatar
Just drive around easy on it. Most people don't have any problems at 10 psi with those mods and the base map, but it's better to be careful. If you can get comfortable enough with the Commander, you can always richen up the PIM voltages 3-5% under boost just to be safer.
Old Jan 6, 2005 | 11:09 PM
ZoomZoom's Avatar
SEMI-PRO
if you say not tuned im assuming you probably havnt changed the PFC settings for the bigger injectors either? in this case the car prob wont even start. Or at leats when it switches to the sec inj around 3k rpms it will die or shudder. Get it tuned. thats too much money to waste.
Old Jan 6, 2005 | 11:32 PM
buzzer's Avatar
how would i go about setting the Power Fc to read 1300cc injectors?
Old Jan 6, 2005 | 11:38 PM
ZoomZoom's Avatar
SEMI-PRO
I never did it myself but you will need at least the commander and most likely a datalogic. You have to change not only the size but the offset/lagtime. PM CCARLISI, he will be able to give you that info.
Old Jul 19, 2005 | 10:48 PM
Taikutsu's Avatar
ooo...i need to know what to change the lag time to too...
Old Jul 29, 2005 | 01:55 PM
BlueSprite's Avatar
the lag time should be calculate by your prior inj and current inj. , i believe.
When you open the pfc's instrustion book, it will give you a tips about it.
fastrx7man
33
Sep 2, 2015 09:42 PM
