How much INSTANT HP is a Front Mount Intercooler worth?
Old Dec 11, 2001 | 12:45 AM
ROSHX7's Avatar
Keeping everything the same and not turning up the BOOST even more, how much HP can I expect from slapping on a decent size FRONT MOUNT intercooler?
Old Dec 11, 2001 | 01:23 AM
Node's Avatar
depends on which FMIC etc etc.
Old Dec 11, 2001 | 01:30 AM
Agent_D's Avatar
rawr
just guessing i would say between 35-45hp, but not sure
Old Dec 11, 2001 | 01:38 AM
Scott 89t2's Avatar
SOLD THE RX-7!
haha, not that much. your lag will increase a little bit too.
Old Dec 11, 2001 | 02:03 AM
Node's Avatar
density change = (orignal absolute temperature/final absolute temperature) -1
intercooler drag
power loss = 1 - (14.7 - psi before intercooler / 14.7 - psi after intercooler)
Ta = temp of ambient air going into turbo
Tco = temp of air coming out of compressor
Tio = temp of air coming out of intercooler
Intercooler Efficiency = Ei
Temprise = Tco - Ta
Temp removed = Tco - Tio
Ei = (Tco - Tio) / (Tco - Ta)
YAY!@!@$
Old Dec 11, 2001 | 02:07 AM
B430's Avatar
that's an impossible question to answer, there's too many variables. you could even lose power (not likely, but it's possible)
Old Dec 11, 2001 | 03:27 AM
HWO's Avatar
HWO
inteligent extratarestril
Re: How much INSTANT HP is a Front Mount Intercooler worth?
at a guess, i'd say you'd get a more accurate answer asking how long a piece of string is.........
Old Dec 11, 2001 | 08:52 AM
Gene's Avatar
10 lb. boost, 5lb. bag
twice the distance from the center to either end of course!
Old Dec 11, 2001 | 09:25 AM
fastrotaries's Avatar
W. TX chirpin Monkey
In Particular i would like to know what type of gains are normaly achieved with a front mount I/C from a starion or similar set up. I can't imaigne it being worse than the stock set up. The only thing left stock on my car is the motor, I/C and Turbo.
rotor_veux
46
Jun 12, 2018 10:39 AM
