Sponsored by: CARiD
i notice diffrential fluid in rear end!! HELP!!!!
Old Dec 10, 2001 | 10:25 PM
stevecod's Avatar
I was under my car taking my exhaust off and notice the right side of the diffrential has a whole lot of fluid all over. i checked all my boots and there are no rips in them. I try tighting the bolts in the rear of the diffrential and they all seem to be real tight.
WHAT COULD IT BE!!!!??????!!!!!??? my friend was behind me while i was driving my car and he said that he notice my right rear wheel seems to be whoppoling a bit, something like the wheel is not tighten. I try tighting the lug nuts and they are all real tight.
it happened after i had a local shop install the lowering springs for me. any help would be great.
steve
Old Dec 12, 2001 | 09:58 AM
Silkworm's Avatar
Has been.. hangin' around
Clean it real good, go drive it, and see where you have leaks. There are plenty of places you could be leaking, I have no idea which it is.
PaulC
Old Dec 18, 2001 | 08:19 PM
atihun's Avatar
Steve,
More than likely, it is coming from where the shaft goes into the diff. There is a seal in there that needs to be replaced. Check the shop manual.
Th0m4s
Feb 26, 2019 02:04 AM
coltboostin
Rotary Drag Racing
Aug 20, 2015 11:37 PM
