Please Help!!!!
Old Dec 9, 2001 | 08:40 PM
Canibus's Avatar
Please Help!!!!
I need these parts . These are mazda trix prices . Where can i get these for cheaper??]
-111A-N370.....GASKET IN MANIFOLD....89-92 TURBO............ $ 5.51
13-1130-8527.....GASKET IN MANIFOLD....WATER JACKET O-RING.... $ 3.30 2pcs
13-112A-N370.....GASKET INTAKE CENTER..89-92 TURBO............ $ 2.84
3.5mm vacuum hose black 30’
16328MZ..........PLATE COVER ACV.......86-92 TURBO............ $ 5.75
11910............OIL COOLER HOSE SET...86-92 STAINLESS.......$ 182.00
11901............ADAPTER -10 16MM THD..-85 COOLER + ALL FC.... $ 9.50
11902............ADAPTER -10 18MM THD..86+ COOLER + ALL RH.... $ 9.50
14-690A-N318.....OIL INJECTOR LINE.....TB 86-88 F HOUSING.....$ 20.47
14-670B-N318.....OIL INJECTOR LINE.....TB 86-88 F INTAKE M....$ 20.47
14-680B-N318.....OIL INJECTOR LINE.....TB 86-88 R HOUSING.....$ 20.47
14-660B-N318.....OIL INJECTOR LINE.....TB 86-88 R INTAKE M....$ 19.01
All oil injection crush washers
11479............PULLEY ALTERNATOR.....DOUBLE BELT ALUMINUM...$ 44.00
thermostat gasket
15-1710-8AF1.....THERMOSTAT............86-88 180..............$ 15.12
13-5350-N386.....GASKET WATER INLET....TO TURBO 86-92......... $ 2.09
13-4610-N386.....GASKET EXH MANIFOLD...86-92 TURBO............$ 59.42
13-5460-N318.....HOSE WATER 86-92 TB...W/P HSG TO TURBO....... $ 5.78
oil return line to engine gasket
16-5100-F853.....CLUTCH T/O BEARING....86-88 TURBO............$ 43.04
11-D030-N326.....CLUTCH PILOT BRG......ALL ROTARY 74-ON....... $ 9.37
11-4040-1881.....CLUTCH PILOT SEAL.....ALL ROTARY 74-ON....... $ 2.41
Old Dec 9, 2001 | 09:35 PM
Canibus's Avatar
Anyone?????????????
