EGT's in the manifold
Old Dec 17, 2004 | 10:43 AM
93rotorhead's Avatar
I want to run 2 egt gauges, one for each rotor and use the groundzero LIM.
Where is the best place for the probes( how many inches from rotor) I heard the collector is a good spot but I cant measure each rotor there. What temps should I see if the probes are pre turbo?
Thanks in advance
Old Dec 19, 2004 | 12:51 PM
Anyone
Old Dec 19, 2004 | 01:04 PM
MrRx's Avatar
Rotary on a budget
assuming you are running a single turbo, just put them both about 3 inch back from the engine. i wouldent be supirzed to see 1600 F a lot
Old Dec 19, 2004 | 01:16 PM
rotarypower101's Avatar
sdrawkcab
Get in touch with Ralph from GZ, he said that he actually had the EGT probes in the housings themselves (if I remember correctly) to get the most accurate nontainted results he could. Which really was the basis for wanting to create a manifold that could feed equaled amounts of air to the rotors and help equal out the EGTs
Old Dec 19, 2004 | 08:16 PM
Thanks Ill try and talk to Ralph
Turblown
Mar 21, 2018 11:19 AM
iamsisyphus
Sep 27, 2015 01:42 PM
