ignition timer and amp
Old Dec 8, 2001 | 11:24 PM
kamisama12's Avatar
okay i want to get a good ignition timer and amp but i need advice on what type to get. please if you can include a link to a web store. one last thing what size do i need to get on black magic elec fan. thanks
Old Dec 9, 2001 | 12:09 AM
niner's Avatar
i dont quite understand what you are askin...
if you want an ignition box i recomment crane hi-6, which you can get from jegs.com or summit.com for around $160
as far as the fan, im not sure. but plenty of people have done it here so they should be able to help
Old Dec 9, 2001 | 01:59 PM
fastrotaries's Avatar
W. TX chirpin Monkey
I have a 16" SPAL electric fan cost about $145 w/o the thermostat from www.racesearch.com . It flows 2,300 CFM and hasn't caused the car to overheat. It survived the west texas summer which frequently sees 100+ degrees. Not even in traffic did it over heat. It is a buit noisy though, but in a cool sort of way. I would recommend rodding out the radiator and changing your thermostat to a NEW OE MAZDA one. I did that 4 months before the fan, so take that into consideration. good luck.
Oh yeah it idles and accelerates better too. plus there's a hell of a lot more room
GKW
Sep 28, 2015 04:34 PM
subeone
Sep 24, 2015 09:58 PM
