Bad Vibrations!?!?
Old Dec 8, 2001 | 07:37 PM
PlayinW/Wankel's Avatar
Bad Vibrations!?!?
hey guys I need some help. My the steering wheel of my completely stock 88 SE starts to shake like crazy up around 75-80 it shakes so bad I dont like taking it up over 100 that often. What could cause this, I would like to fix the problem ASAP, because it is really annoying. Has any one else had this problem, If so how did you fix it. Thanks
Old Dec 8, 2001 | 08:57 PM
Come on guys, some one has to know what the problem is
Old Dec 8, 2001 | 10:22 PM
PaulC's Avatar
Three spinning triangles
From: Been all around this world and still call Texas home (Ft Worth)
bushings, struts, alignment, idler arms, steering rack/power steering?? Could be any number of things. Take it to a respectable shop. they should be able to tell you. Could be something as simple as a tire/wheel being out of balance.
Old Dec 9, 2001 | 12:19 AM
mikejcyr's Avatar
Newbie
Most of the time it is as simple as the tire/s being out of balance. Get them balanced and the shop can tell you if either of the front were way out of balanced. If so you found your problem for very low cost.
squirrels
Sep 1, 2024 09:52 AM
Logan Reinisch
44
Sep 17, 2018 12:20 PM
Jmpabon93
Sep 30, 2015 04:57 PM
