Engine Management Forum Use this area for discussing Haltech, Wolf 3D, Power FC, AEM and any other aftermarket ECU upgrades. Help/Questions/Tuning
I need INTERACQ Software for the Purple Box
Old Dec 8, 2004 | 03:40 PM
I am looking for the INTERACQ software for the Peter Farrel or EFI Engine Management Systems. Can anyone help me out?
LJ
Old Dec 8, 2004 | 03:52 PM
Mr. Stock's Avatar
1993 RX7 R1
I have this at home someplace.
I'll look for it and PM you if I find it.
Old Dec 8, 2004 | 04:24 PM
zullo's Avatar
Obsessed
My understanding is that the software is registered/bound to its hardware so it is unlikely it will work with your box. However, if it does, or if you are able to register it and get it to work, let us know, cuz I would like to find a copy also.
Old Dec 8, 2004 | 04:33 PM
iceman4357's Avatar
me three ive been looking for it for about a year now and i cant find someone that has it!!!!
Old Dec 8, 2004 | 04:46 PM
a3dcadman's Avatar
interacq! count me in also. apparently, it comes on a floppy disk. i might know someone that can figure out the code to circumvent the hardware to software locking interface, just need a copy of the disk.
ive done quite a bit of research on this software issue and have found that the software is not handled by efi or pfs but by a separate company which i have the info for somewhere.
chuck
Old Dec 8, 2004 | 06:37 PM
jsplit's Avatar
Everyone seems to say that the software is bound to the hardware, so unless you buy your purple box with the software from someone I think you're pretty much out of luck.
What do you really need the software for? If you need help tuning the box I can point you in the right direction.
Old Dec 8, 2004 | 08:41 PM
zullo's Avatar
Obsessed
The software gives finer granularity maps than the hand unit, whose fuel/timing maps are only 4 by 4 data points (iirc)... I believe the software gives you either 4 by 16 or 16 by 16 points. That aside, it also offers logging capabilities and you may be able to run the purple box standalone with the software, not sure... probably some other features too, but a large part of it is to ditch that 2-line controller lcd display.
Old Dec 8, 2004 | 10:41 PM
the_saint's Avatar
Hey Mr Stock, help out a fellow doc.
Old Dec 8, 2004 | 10:44 PM
Speed of light's Avatar
Form follows function
I'm looking too, for a later (windows) version. Early versions are dos.
Old Dec 8, 2004 | 11:25 PM
The company is called Plus 1 Micro. I called the guy today and he said it would be 250 bones for him to send me a copy. I dont think its worth that, especially for software built on windows 95. Hopefully someone can find a copy for a reasonable price.
Old Dec 9, 2004 | 12:14 AM
Mr. Stock's Avatar
1993 RX7 R1
I am not even sure which version I have(DOS or Windows).
I looked in my study with no luck.
I will look in the boxes stored in my garage in the next few days.
Old Dec 9, 2004 | 01:48 AM
iceman4357's Avatar
i have the old DOS version, but its only good for datalogging. Im looking for the Windows version where you can edit your maps. If anyone has a copy PLEASE help us out!!
Old Dec 9, 2004 | 02:05 PM
Iceman, can you help us out with the datalogging software at least.
Old Dec 9, 2004 | 08:47 PM
a3dcadman's Avatar
hmmm. from what i have been able to determine, the software is also set up to work with specific firmware modules in the pfs box and that for everything to work they must be compatable, not to mention the hardware software locking aspect.
so, did plusone micro say anything about sending the pfs box in to have it set up for the software or providing updated firmware chips with the software. did they even ask what firmware version the box was to check for compatability
chuck
Old Dec 9, 2004 | 08:53 PM
No, they didnt say anything about having to see the software. I think the way the lock works is it writes the seriel number of the PMS into the disk when u install it. I dont think it has any hardware matching beyond that.
Old Dec 11, 2004 | 08:36 PM
iceman4357's Avatar
Any updates? I gave my copy to someone here....but its the old version. We need to find the windows version!!!! I cant believe that no one on this board has it!
Old Dec 11, 2004 | 08:56 PM
We could pool our resources and just buy a copy. Any interest?
Old Dec 12, 2004 | 07:19 PM
iceman4357's Avatar
hmmmm.. thinking about it
Old Dec 13, 2004 | 12:07 AM
a3dcadman's Avatar
that thought crossed my mind. nobody provides support for the system any more, so why not.
Old Dec 13, 2004 | 07:36 PM
sevensheaven's Avatar
REPU Wanter
Count me in, I would love hooking up my laptop!! How can we all get something going on this?
Old Dec 13, 2004 | 07:38 PM
REPU Wanter
While were on the subject does anyone have an extra jumper cable for the PFS PMC? I got a decent deal on a used box, but the guy said he didn't trust the adaper plug and soldered his in. My luck he threw the old adapter piece away.
Old Dec 13, 2004 | 07:58 PM
What cable or adapter are you talking about? The one that goes to the handheld or laptop is just a standard RS-232 type com cable with DB-9 shells on each end.
Check your Purple box version: If you don't know what version your hardware / prom is, you can easily check this by plugging the com cable into your laptop's com port while using a terminal emulator, i.e., hyperterminal, etc., and then turn your ignition on. The PMS purple box will output an ascii text string to report its version and date during initialization.
Old Dec 14, 2004 | 11:38 AM
iceman4357's Avatar
it would be hard for us to get the software because no one supports it, and everyone might have a difference version. We just need to find someone who has a copy and distribute it!!!
Old Dec 14, 2004 | 08:05 PM
REPU Wanter
I guess I wasn't specific enough. I need the harness that plugs into the car and computer and purple box.
Old Dec 14, 2004 | 09:39 PM
zullo's Avatar
Obsessed
Sounds great - as long as I get to install it first -
